Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
No Video Output
I have installed a new mother board, k7s741mg, and I have no video out put. I am using the video board built in to the mother board. I have installed new memory sticks.(512 total) Everything seems to be booting. The hard drive starts, and cd is also running. Just no video to complete installing drivers from the cd. How do I get a "picture"?
What have I done wrong, or will the vga monitor work properly if this is set as agp? Help
  • Anonymous Jul 31, 2008
    I assembled a bundle type motherboard (K8M890M2MA-RS2H) + AMD Sempron LE1150. Problem no video output error message "No Signal". Can you assis in this instance.
    Rey Ayuyao
  • 112 Answers
Do you get any picture at all?
Can you press the F1 key or DELETE key and bring up the Setup menu? Can you see it?
If you can't see the above, it sounds like someone was not grounded to the computer case when they installed the new motherboard. Static electricy is the #1 killer to all electronics. If this is the case, you will have to buy an aftermarket video card and install it to see anything.
The VGA monitor will work with any video cards on the market.
If the motherboard said that it uses an AGP video card. That is the only one it will use. Make sure the card matches the motherboard or it will not work. All video cards are marked on the outside top of the box and your motherboard is maked by the AGP slot. Make sure you get the right speed format also. 8X will only work with a 8X.
I hope this helps and I will check back later to see how you made out.
Posted on Apr 02, 2008
I have no video output. The mother board is an
hello, if you not having any video out put then they may be problem with your connection CPU to MONITOR so check the VGA port connection and if problem consist then it may happen that your VGA card is damaged so pleas check out to your engineer for the same..
May 11, 2010 | Computers & Internet
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Jun 22, 2009 | Computers & Internet
I don't know what to do.
sounds like you need a new mother board retun video card find mother board with built in video card
Jan 02, 2009 | Biostar P4M890-M7 (P4M890-M7 PCI-E)...
K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
Dec 16, 2008 | Computers & Internet
Sound quality
The sound quality built in to most mother boards is not the best quality. It is a compromise. The best solution is to install a high quality sound card in an available slot.
For video quality, it is the same issue when it comes to high quality video.
Before installing the new sound card, uninstall the existing sound drivers and sound software for the built in sound as necessary. You may have to go in to the BIOS set-up and dissable the mother board's built in sound. It is best to consult the instructions for *********** board to know the details for the particular mother board. You should contact the dealer for your computer to have proper details.
Turn off the computer, and disconnect the AC cord. Open the case, and install the new sound card according to the instructions that come with it.
When the computer re-starts, it should tell you that it found new hardware. Go through the installation procedure. There will be drivers and some software and drivers that must be installed.
If you are not used to this type of procedure, it would be best for you to take the computer to a computer service place and have them do the installation for you.
Jerry G.
Sep 13, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
On board video...
The BIOS will most likely be set to auto detect, when you physically install the new card the BIOS should detect it and auto disable the onboard video.
Aug 02, 2008 | Dell Dimension 3000 PC Desktop
If you plug in a pci video card, sometimes the bios, not Windows disables the card on board.
If the onboard video is not being disabled from bios, then you will be able to use either one or the other video cards, no need to disable it manually.
If your system takes both cards and you want to disable one, then go to system properies/hardware/device manager and disable the unwanted video card from device list by ticking disable on device profile.
Jun 06, 2008 | Foxconn K7S741MG-6L Motherboard
Video output
April fools?
make sure the power is on, cables connected, all components are working and installed correctly?
Apr 01, 2008 | Foxconn K7S741MG-6L Motherboard
No Video Output
What video card are you using?
No Video Output - New RAM - Tried Most Things
Without sounding silly. Have you tried replacing your new memory with your old memory? Just to see if your Pc boots normally. This will narrow down the root cause. This board only will only handel this type of memory.
Single channel, unbuffered, 2.5V DDR266/333/400, (2)184-pin DIMM sockets, max 2GB
Feb 08, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
108 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
