Question about Refrigerators
Fridge on side during transportation when can it be plugged in?
    President:
  • Refrigerators Master
  • 2,651 Answers
Sure but you need to let stand with out plugging in for
AT LEAST 24 HOURS. all oils need to return to compressor area, turning on premature will trap oil in the evao andcndensor and thats fatal!!!!!!
Posted on Apr 02, 2008
Can I transport one of your 2 door Fridge/ freezers laying on its side.
only transport a fridge or freezer on it's side if the upright transport is NOT an option.
any chiller using compressed liquid/gas and placed on it's side should be left for 24 hours to settle before powering at the mains, this will allow the coolant time to sink where it should be and prevent the pump (& chiller) from failing.
Nov 23, 2017 | Refrigerators
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
Can you transport this fridge on it's side?? kenmore side by side fridge 22 porcelain plus
Not recommended, but if you must, set it upright but don't plug in for 2 days so all fluids and oil can settle back into the compressor
Jun 10, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
New fridge coming today...
Good day,
If it's being delivered by an appliance company, they know that the machine has to be transported upright. So no. You should be able to plug it in as soon as it's set up.
IF the machine is transported on it's side, then yes, a minimum of 24 hours is necessary to get the oil back into the compressor.
Jun 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What causes my fridge to run hot? It thinks its an oven! It was working fine prior to transportation, after which it was left for three hour prior to switching on when it ran hot.
I believe it may have been laid down during transport. Leave it unplugged for another 24 hours and allow the compressor oil to return back down to the compressor. This is a very common problem if laid down on side during transport. After this time replug the power cord and listen and feel to insure warm air blows from bottom of refrigerator and cold air in freezer. The oil is to thick and heavy to be pushed through the capillary tube. Just be patient and not try to push the time getting it to cool again as the compressor will continue to overheat if oil remains in the cap tube. Thanks Sea Breeze
Mar 12, 2010 | Maytag MSD2454G Side by Side Refrigerator
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
When moving the fridge with a built in door dispenser do I need to plug something first before the move? Do I need new lines after the move?
You can cover the lines to prevent any contamination but it is not necessary, the main thing in moving a refrigerator is to keep it upright during the move. If this is not possible and you have to lay it on its side, wait for at least 12 to 24 hours before plugging it in when you arrive at your new home.
If it is transported on its side and you plug it in too soon you can get liquid refrigerent in the compressor, which will knock it out leading to costly repair and replacment.
Jun 07, 2009 | GE Profile PSI23NCR Side by Side...
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Transported a fridge on its side, waited 24hrs, plugged in.
Transporting frig on side probably damaged the compressor due to the oil inside draining from bottom. Do you know if the bulbs were working before you purchased? If they were you may have damaged the door switch, easy fix, just replace. Compressor replacement should be left to a pro. Probably looking at a couple hundred. One other thought is you might have caused a gas leak during transporting, another job for a pro.
Feb 23, 2009 | Frigidaire FRT18G4A Top Freezer...
Kenmore fidge not getting cold
transporting fridge items on the side mixes up the oil and the gas together, inside the compressor bottle at the back, this should never be mixed, when you move fridge appliances you should always stand appliance where it is going to be for 24 hours before switching back on to allow the gas and oil to settle and separate back apart again. many engineers may tell you this does not matter and you can lay items down etc, this is absolute bull and must not be done as for allowing it to stand 24 hours, the opinion is mixed, but common sense tell you, if you move something, let it settle afterwards, and the longer you give it to do so the better OBVIOUSLY sorry there is no diy repair
Oct 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
