Question about JVC TH-C50 System
JVC 8 pin pinout - speaker cable
Hi I called JVC no dice on the pinout diagram, I took the back off the sub no help there..it's all cards and pathways, no wires to copy down. Some one must be capable of figuring the pin to speaker and common using a meter. Now I wish I had that skill. email me if you have a pinout, or make custom breakout cords. thanks B. bmysticmale-0608@yahoo.com
  • tjh6767 Mar 14, 2009
    I need the wire color schematics to fix my cord. It is for model THC5
  • girtas Apr 06, 2009
    Hi Cyphet !
    What pins to use if I want to input single stereo signal in simple amplifier (another audio system aux-in) ? Left, Right, Speaker Ground ?
    Regards,
    Girts
    a.girts [a t] gmail dot com
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Posted on Dec 10, 2008
  • rabeyta709 Mar 02, 2011
    I have a Th-c50 unit and don't have the subwoofer system cord, can you use a regular s-cord to make that conection? or is my system useless with out it?
  • 682 Answers
Http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Posted on Apr 06, 2008
Sold mine a few years but as I recall, speakers were easily connected to the Subwoofer. R U trying to extend the cable from the DVD player to the Sub? If U R, there is an Apple printer cable that works perfectly. Hope this helps
Posted on Jul 10, 2008
SOURCE:
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Someone gave me a YST-MS50. The left speaker (no controls) does not work. It is not the speaker or the cable from the main unit to that speaker. I find that only 7 of the 8 wires in the 8 pin cable going...
If you don't get it to work would you be willing to sell me the right satellite speaker with the controls? email me: red...4..dsc..@....g..mail.com... (just take out all the dots)
Dec 05, 2010 | Yamaha YST-MS50 Computer Speakers
X-220 cable is slightly damaged and not making constant contact with sub-woofer mate. Is there a repair where I can replace or cut open & fix the 9 pin cable? To me, the obvious problem is that the...
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Aug 07, 2010 | Logitech X-220 Computer Speakers
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
JVC DVD players
Use a sling for multiconnection to connect 8 pin input;
Sling Media - Slingbox
Jul 19, 2008 | Audio Players & Recorders
JVC THR1 DVD Digital home cinema system.
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
Jul 17, 2008 | Audio Players & Recorders
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
JVC TH-C50 System Logo
7,618 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
