Question about Dishwashers
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to remove and clean. The one on the left moves up and down but i can't seem to be able to remove it (without breaking it). Any advice? Thanks
What must I do if the rinse compartment is plugged???
help please. My moms dishes are piling up. my hands are all pruiny from hand washing!!!
Posted on Aug 01, 2010
I have the same model. i have to clean out the sprayer arm about 1x per month in order for sihes to get clean. i remove it from unit and hold it over sink. using very small tweezers i remove crud from the holes. by running water through and truning it over several times you can get the pieces of crud to fill the holes and then remove them.
Posted on May 16, 2008
  • 53 Answers
Hi
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Posted on Apr 01, 2008
Dishwasher won't drain
You may need to clean out the trap below the dish rack in the bottom of the machine. Remove any debris that may be in the floor of the washer. For a Frigidaire, I know you push down and turn the trap clockwise until it releases; remove the trap by pulling up on the water jet; remove the glass trap and empty, then clean any debris below or around the trap; replace the glass trap, replace the water jet, turn counter-clockwise until it clicks; replace the dish rack. Be sure to use mild cleanser, such as dish soap or vinegar--no harsh chemicals as they will damage the machine. Good Luck!
Oct 03, 2017 | Dishwashers
Mdc4650awb stopped working
Is it running to a point or not turning on at all. If it runs to the point when it should pump out the water and stops, then it's not the boards or electrical. I have found with dish washers that they need a good cleaning every 6 months. Dismantle the rotating arms, take out the parts underneath and remove the filters all the way to where the water enters the pump. There's often grease and blockages here. The rotating arms also get stuff forced through them that clogs the outlet holes, so dishes don't get as clean. I've found orange seeds jammed in the outlet holes that then swell up with the extra water. Hair gets in and traps grease and all kinds of stuff. I've found the plastic wrappers from dishwashing "pods" clogging the filters. You'll find everything from toothpicks to bits of bone people leave on their plates
Sep 30, 2014 | Maytag 24" Tall Tub Portable Dishwasher -...
How to clean the drin filter
If there is enough room put a large adjustable or water pump pliers on the cover,i used the adjustable and put a screwdriver through the hole in the end and very gently applied pressure until in moved, I sprayed a little lube in the space between the cover and housing and it came off much easier then. There was so much debris in the trap and it stinks really bad, a large dish is needed under the cover as a lot of water will come out. Clean out the trap and reassemble using vaseline or grease to help the o ring seal.
May 23, 2014 | Maytag MHWE200XW Washer
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Top shelf dishes aren't getting clean in my 5 year old Whirlpool dishwasher. Any suggestions?
The most likely reason the dishes in the uppper rack of your dishawasher are not getting clean is because the filter on the pump is built up withe debris and the water is havinga tough time circulating through the pump. This tip i wrote will show ya how to clean that filter.
http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 18, 2011 | Whirlpool Dishwashers
Have a Maytag MDB4000AWW dishwasher that now leaves white residue on glassware. I think that the water is not getting hot enough. Does this model increase the water temperature, if yes how do you test that...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 08, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Does not get dishes clean
There is a filter/trap located at the bottom of the machine held in place by 2 1/4 screws. This trap will be located at the lowest point in the dishwasher. Once the two screws are removed there is a lower tub that may have a bit of food debris in it. Sometimes there is food particles that do not get flushed out into the drain. Clean this area and you should be in good shape
Dave
Jan 13, 2010 | LG Dishwashers
Cloudy and dirty dishes after washing
I found this for you on YouTube. I don't think that you want to go to the extreme lengths that this guy did, but he does show how to disassemble the inside portion of your washer so you can get to the parts that need cleaning. This should get you back up and running, with sparkling dishes, and a big smile on your face! There are also oyher videos there, some selling products that may help.
http://www.youtube.com/watch?v=JhchaOhpQQo
Best regards, --W/D--
Aug 08, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dish washer not getting the plates clean.
WHAT KIND OF DETERGENT ARE YOU USING?
Jan 08, 2009 | Dishwashers
Dishwashers Logo
1,057 people viewed this question
Top Dishwashers Experts
