Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Water leak every time we use the water dispenser we get water leaking inside of fridge
  • slong10594 Oct 15, 2008
    i also have a leak when i turn on the water dispenser it looks to be coming from the plastic hose tube behind the vegetable drawers. there is a leak in tube. do you know if i can replace this part myself and how much it costs or what is it called? thanks
  • robert samples May 11, 2010
    its not from the water disp its not built that way where is it and how much stop using and see if you still get water and let me know also see if there is ice built up in bottom of freezer
I am having the same problem. I do have a light layer of ice at the bootm of the freezer.
Posted on May 10, 2008
My Whitlpool Gold fridge GDSSHG is leaking water inside when the ice maker fills. Seems to be running down the back behind the metal backing and into the Bottom of fridge. Freezes there and then when that...
2 possible issues: 1st and most likely, water valve got stuck in open position - you need to shut water at the back of Your fridge and get new water valve. 2nd seen only couple times: when ice maker stuck in position when its calling for water, so valve opened all the time. As I said water valve 90% of a chance is bad. Hope that helps.
Mar 28, 2015 | Refrigerators
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
GE GSS22JFMC when I press the water button it leaks
That's where the water line runs to get to the dispenser. You may have to remove the cardboard backing to see it. The line runs from the water inlet valve. That's where the supply line from the house connects to the fridge. One line goes up to the ice maker and the other goes over to the fridge side where it goes inside the fridge behind the crisper to a reservoir where the water is chilled before it goes to the dispenser. Look for the water coming out when someone else tries the dispenser. Look for a fitting that has come loose.
Oct 02, 2009 | Refrigerators
My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Jun 23, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Fridge has water in it which freezes into sheets.
see if there is a drain line going up the back if there is you should be able to take if loose to see if its stopped up
Apr 24, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Amana Side by side refridgerator Model SBD20TPE P1190006WE
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: :
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
150 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
