Question about Maytag SkyBox MBV1976A Beverage Dispenser
Sky box I also have a shybox that has stopped cooling..can i get a copy of manual and can you recharge this unit and where is charge port ?
  • 770 Answers
What is your email?
Posted on Apr 28, 2008
Can you recharge. a dometic a/c rooftop unit serial number 991762724
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Aug 29, 2014 | Brisk Air Dometic A/C Roof Top Air...
Recharge freon banded
Yes. If it has a port installed from factory, it can be recharged. If it used R12, it can be purchased from Ebay. It the unit does not have a recharging port, you can also purchase that from Ebay. You need to know the size of tubing the port is going on. A pressure guage would also help troubleshooting.
Oct 06, 2013 | LG Electronic Window Air Conditioner
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Where to I recharge my freon in a 2000 ford escort?
Look for an aluminum tube approximately 1/2 inch in diameter with a stub sticking out
of it with a black cap on it. This is the charge port. Unscrew the cap. There will be an aluminum stub. The recharge can should have a gauge on it, slide the collar back and
push it onto the stub Charge only into the middle of the green zone on the gauge when
the air temp is around 80 degrees and with the engine and A/C running. If all is ok
with refrigerant charge but not cooling then it may be a clogged accumulator or even
malfunctioning radiator fans (it wont cool at stop lights when this happens). Hope this is useful.
Jun 13, 2011 | 2000 Ford Escort
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.,VEC010BD.pdf
Have a great day.
Dec 30, 2010 | Vacuums
Do you recharge air conditioner on upper port or lower port
you always recharge on the suction side near the compressor. wear safty goggles!!!!This is the largest line and it will have a pin valve on the line for charging.Look for a sight glass ,it will be on the high pressure line near the dryer assy,a much smaller hose-line it will also have a pin type valve like a tire valve,the site glass is used to see if you are near full charge while recharging,buy observing bubbles.. if the unit is cooling the low side or line for charging will be cold,dripping with condensation on a hot day,and frosty on a cold day.if the system is low it will be warm and dry. but if it is low enough to be less than 50 psi the compressor will not opperate.
Sep 01, 2010 | 1994 Jeep Grand Cherokee
Can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerator stoped cooling
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Will not take a charge. took two charges prior but has now stopped
I found this online at under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
83 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
