Question about Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset
BT160 connect problems
My phone needed to be replaced because the screen went blank. When I replaced it, I had to re-connect my bluetooth, but I can't seem to do it. My phone is an LG8300. Can u help me connect my bluetooth? Thank you
    Genius:
  • 1,019 Answers
while your in the phones bluetooth manager/program and searching for the device. press the bluetooths buttons to enable the 2 to syncronise. if you press the up/down volume buttons while searching with the phone, it should find it, and syncronise. by pressing different buttons, your giving the phone a chance to detect a bluetooth signal change, and receive the device.
Mike @ compurepair.
Posted on Apr 01, 2008
How do you put the device into discovery mode
Before you use your Jabra BT160, you need to pair it with your mobile phone. 1. Put the headsetin pairing2 mode Make sure that the headset is on. Press the answer/endbutton and press the volume up (+) button at the same time, until asolid blue light comes on. 2. Set your Bluetooth phoneto ?discover? the Jabra BT160 Follow your phone?s instruction guide.This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menuon your phone and selecting the option to ?discover? or ?add? aBluetooth device 3. Your phone will find the Jabra BT160 Your phonethen asks if you want to pair with it. Accept by pressing ?Yes? or ?OK?on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case ofunsuccessful pairing, repeat steps 1 to 3.
USER GUIDE
Jan 03, 2010 | Jabra COMMUNICATIONS BT160 Bluetooth...
My motoralo razr does not want to pair with my bluetooth Jabra bt160
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Nov 03, 2009 | Jabra BT160 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Jabra BT160
The default Jabra password seems to be 0000
Give it a try - it may work
Good luck
Feb 25, 2008 | Jabra COMMUNICATIONS BT160 Bluetooth...
Connecting to phone
You need to put Jabra in Discovery Mode. Press the "Volume up" and the "Power" button at the same time continuosly while you have your Razr in the add Bluetooth mode. Once they meet you will be asked to pair, concur. Then you wilkl be asked for a passkey.. The universal code is "0000" (4 zero's).
This should get you in and working.
Nov 09, 2007 | Jabra BT160 Wireless Headset
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Screen Blanks, Phone Turns Off Sporadically
Looks like a battery problem. You might want to replace it.
Sep 05, 2007 | Motorola Mobility RAZR V3
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset Logo
79 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
