Question about Refrigerators
Have a small dent/puncture from a screw driver "gone wild" on the lower half of LG titanium look fridge...can this be repaired in any way?
    President:
  • 1,314 Answers
Well could get some expoty putty and stuff in it then spritz it with silver paint high gloss or replace the door
Posted on Apr 02, 2008
SOURCE:
How do i fix and replace a freon leak?
If the leak is able to be seen and easy to get at you might want to take it where they replace parts for fridges and see if they can solder the holes. That's what repair people do when you have a Freon leak in a fridge.
Jun 26, 2017 | Heating & Cooling
Tip
Cheap dent puller for small dings/dents
you can fabricate a dent puller to repair small dents on your body panel(s)
just weld/solder a phillips head screw to a phillips screwdriver. a slide can also be added to your puller by obtaining a 4"-5" long 1" i.d. steel pipe. slide pipe peice over driver shaft, then, obtain a bolt washer clearenced enought to slide onto driver shaft in front of the peice of pipe, weld/solder washer to driver shaft and you have a stopper to limit forward travel of the peice of pipe.
on Mar 27, 2009 | 1997 Dodge Ram 1500 Club Cab
How do I repair a dent in the door of my stainless steel refrigerator?
if the dent is not creased; use a suctioncup dent puller availlible at any autoparts store
Feb 04, 2013 | LG LFX25960ST Stainless Steel French Door...
Whirlpool fridge freezer stopped making ice
Make sure the freezer plug cord has power on the outlet. Also check the thermostat control if working, in desired settings especially in low degrees, it should have some freeze. If not, then thermostat is defective.
See to it that the evaporator has no dent, punctured cause by sharp object ( knife, screw driver, etc.) when removing frozen food or drinks. If it has small hole, it will cause refrigerant to evaporate hence freezer will stop making ice.
A defective defrost timer will also cause that same problem. You will know it by dialing the knob, it should smooth and no friction and if it has failed to go back to original position.
Thanks for asking.
Jul 03, 2011 | Whirlpool Refrigerators
Small dent in stainless steel fridge door how can I fix it?
Purchase a small piece of dry ice to aid in repairing any small dents. Carefully hold the dry ice with clamps or another utensil over the area to pop the dent out. If you have a dent with sharp, well-defined edges the dry ice method may not work as well, and you should either contact the manufacturer to purchase a new panel or a local auto body shop offering paintless dent repair to determine which avenue to pursue.
Finish the repair by wiping the repaired area down with a damp cloth and buff with a separate soft, dry cloth to make the surface shine. If you had to use any touch-up paint or sealer wait until the area is fully dry before you wipe the area.
Apr 05, 2011 | Refrigerators
Fridge section doesnt work at all. lights and door alrm do. just wont get cold
some circuit problem in sensor, clean your ref first throughly inside and back. after that use it see what happen. be sure that the evaporator aluminum tube wire is not damage or punctured dent that may cause's a small hole led to leak the refrigerant.
Feb 02, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
I have small dents in the stainless doors. How do
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
It is more cost effective to replace panels than remove the dents. We can remove scratches but not dents, use DeBruce Polish for maintenance.
Dec 31, 2009 | LG LFX25960 Titanium Bottom Freezer French...
Need a handle for the freezer
heres the parrt number, although i dont really know who supplies the part, i guess you can call lg direct
3651JA1033C titanium handle for freezer door approx $40 US
Apr 07, 2008 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
