Question about Refrigerators
Have a frig over freezer and the frezzer has two lines of water that run out of it constantly creating ice in the the bottom of the freezer sometimes icing in the drawerit get so thick so fast . i have had this frig for three years and am getting tired of this problem. can you help? sharon
  • robert samples May 11, 2010
    brand and model number would help but off hand id say check the defrost drain or the door seals if had info could be more specific model number needs to come off serial plate in fridge also age
We found the problem and were looking for the wrong thing . turns out that the hose to the drain tray had something like caulking blocking it. we cleaned that out after defrosting the freezer and it now works like a charm. if i have any more troble yo'll be the first to know. sharon
Posted on Apr 03, 2008
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Freezer is cold, has ice on bottom. Frig side is constant 50 degrees. It is constantly running also.
the defrost has melted the ice,now the drain tray is plugged and needs a wire run down from the drain in the freezer to the condenser pan so it can evaporate,as this fools the temp thermostat trying to cool the refrige compartment to keep trying to cool the unitif theres water dripping into the fridge rom the freezer this is a good indicator of this problem
Jul 01, 2011 | Refrigerators
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Water running under frig.
have you tried turning the water off(if you have a tap/faucet behind unit).....
Feb 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Bottom freezer constantly runs till it ices up.
check coils on bottom of box and clean out with air or coil brush
Aug 09, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
