I broke my ONKYO circut board for the speaker output # NCST-2620 GCMK-77X anyone know where to find one?
  • 4,234 Answers
You need to contact Onkyo directly. Ask for the parts department.
Dan
Posted on Apr 02, 2008
SOURCE:
How to hook up a Onkyo DV-CP500 5 DVD/CD to a Onkyo AV receiver HT-R500 and a Hitchi 43FDX15BV2G005104 HDTV?
From what I find on the internet, the Receiver and the DVD player do not have any HDMI connections. Therefore, I'm using the S-Video connections. The best way to hook these components up is the following.
DVD player - Use an S-Video Cable on the OUTPUT and connect this to the S-Video Input on the Reciever. Also, connect the two audiot OUTPUTS (red/white) on the DVD player to the RECIEVER's two audio INPUTS (red/white)
RECEIVER - Use an S-Video Cable and connect to the S-VIDEO MONITOR OUTPUT and this will connect to the TV's S-VIDEO.
Speakers will connect to the Left Right Front Speaker, Left Right Rear Speakers, and Center Channel. The sub woofer needs to be connected to the Sub woofer/PreOut terminal on the Receiver.
Oct 23, 2014 | Audio Players & Recorders
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
I can not get my garmin 2620 to talk to me
In order for the GARMIN 2620 to speak to you it must have the speaker attached. The speaker is included on the car adapter plug. Without this special 12V car adapter you will not be able to get sound from the Garmin 2620. If you have the adapter with the built in speaker, make sure the volume isn't muted, and is turned up by pressing and holding the Speak key or adjusting the volume on your 2620 remote.
Nov 10, 2009 | Garmin StreetPilot 2620 GPS Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
I have found the solution.
Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
Jun 19, 2009 | Onkyo M-282 2-Channel Amplifier
Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Speaker boom
there is a bad solder connection on the board in the output circuit
Aug 28, 2008 | Onkyo TX-SR602 Receiver
Noise ...hum
Open up the receiver. Check the fuse. The fuse protects the circut board from overload.
Aug 11, 2008 | Onkyo TX-SR603X Receiver
154 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
