Question about Foxconn K7S741MG-6L Motherboard
Video output I am using the video system built into the mother board. What am I doing wrong, and what shoul I do next? Hub
  • Ken Wood May 11, 2010
    Can you please be more specific? What are the symptoms of your problem and what have you tried already?
  • 13,433 Answers
April fools?
make sure the power is on, cables connected, all components are working and installed correctly?
Posted on Apr 14, 2008
What is a good video card with DVI output for Presario SR1475CL, Product No. PW711AA?
You need to open up the PC and see what kind of slot you have. It will be the one closes to the CPU. Most likely you power supply does not have video card only AUX power cords but if they do then you can get a high end video card. Once you replace the card you will need to tell the BIOS not to use the onboard video card.
May 19, 2014 | HP Computers & Internet
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Jun 22, 2009 | Computers & Internet
No Video
as per your statement u may need to scrap the system
May 11, 2009 | Computers & Internet
Sound driver installation & how to attech internet, hub with lan
Sound Driver:
Download the right Sound driver from manufacturer web site.
look for the Model number and right operating system
after you download it..all you have to do is run the program
if your question is how to find your sound card's Manufacturer and model, some of them have prints of model and manufacturers name on the card.
if your sound card is built in to mother board...check the mother boards manufacturer and go to their support web site...and download the driver.
installing HUB/Switch to your current LAN is plug and play, just connect the network cable (patch) to the router
Mar 13, 2009 | Computers & Internet
I don't know what to do.
sounds like you need a new mother board retun video card find mother board with built in video card
Jan 02, 2009 | Biostar P4M890-M7 (P4M890-M7 PCI-E)...
Do I need a video card for this mainboard?
Since you have able to connect your monitor to the board it means that it has a built in video on the mother board but there's no display on the screen if that's the case there's a possibility that the built in video is not working fine, so I'm suggesting you get a AGP video card because its really better not to use the built in video.
Jun 16, 2008 | MSI PM8M-V Motherboard
No Video Output
Do you get any picture at all?
Can you press the F1 key or DELETE key and bring up the Setup menu? Can you see it?
If you can't see the above, it sounds like someone was not grounded to the computer case when they installed the new motherboard. Static electricy is the #1 killer to all electronics. If this is the case, you will have to buy an aftermarket video card and install it to see anything.
The VGA monitor will work with any video cards on the market.
If the motherboard said that it uses an AGP video card. That is the only one it will use. Make sure the card matches the motherboard or it will not work. All video cards are marked on the outside top of the box and your motherboard is maked by the AGP slot. Make sure you get the right speed format also. 8X will only work with a 8X.
I hope this helps and I will check back later to see how you made out.
Apr 01, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Mother board
Firstly your motherboard doesn't have video capabilities built in so you have an addon video card. I doubt there's any problem with the board as it's jumperless and you can't have the CPU settings wrong. Are you getting any beeps when you switch on? The length and number of beeps can tell you where the problem is. The usual problem with no video is either a memory problem or video card problem. If you can borrow another video card try it. Make sure the plug is correctly inserted all the way in and make sure the video card is properly seated in it's slot. I assume you're using the 4x AGP slot. Remove that and try another ot even a PCI card in the PCI slots. You may then get a picture. Actually apart from finding it hard to figure out your actual problem it's very hard to diagnose a fault from the little you've told me. Certainly the motherboard can be faulty and you won't get video but it's the video card you should be looking at first. Have you turned the monitor on and plugged it in?
Jun 03, 2006 | Acer AOpen AX 6B Plus (91.87810.321)...
Foxconn K7S741MG-6L Motherboard Logo
95 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
