Question about Fellowes PS60C-2 Shredder
Fellows ps60c-2 I have a fellows ps60c-2 shredder and after I removed the seven screws I could not get the powerhead apart. I need to know what is holding it together yet. It also is shredding on the left side but not on the right side (Power switch side). I am pulling it apart because somebody has let loose or broke inside and do you know what this possibly could do or have something to do with the shredding. I would very much appreciate any help. Thanks, jmlaatsch@gmail.com
  • joey5 Apr 02, 2008
    This is expert advice? Can anyone do a little better.
  • pdenyer Dec 15, 2008
    removed the 7 screws holding the housing together, but the housing still won't come apart - some other screw somewhere, or some magic that needs be performed to get the shredded head assembly apart? There something rattling about in the cutter head assembly - be nice to see what came loose and whether it is repairable.
    Problem Solver:
  • 5 Answers
Someone else suggested that there is a screw under a label that needs to be removed. I felt what seemed to be a screw head uner a label but when I cut through the label I found a melted blob of plastic, as if Fellows had decided to replace a screw with a more permanent solution that would stop people taking the shredder apart to try to clear a jam and/or replace parts inside (and therefore force them to buy a new one...)
Posted on Aug 21, 2010
  • Dan Fixer Aug 21, 2010
    Update to my posting of yesterday: It turns out there was a hidden screw hole underneath that same label where I found the plastic "blob" that I had thought was a screw head. Once I found that, I was able to take the shredder apart, pull out the wads of paper (and cardboard that should not have been shredded by the prior owner), applied proper lubrication, reassembled it -- and it still jammed. Apparently the gears in the gearbox are stripped. If I'd worked on more of these I probably would have opened the gear box first to check there. Oh well...
Took schreder apart: The plastic driven gear it striped is that gear serviced
Posted on Mar 23, 2009
    Scholar:
  • 102 Answers
This was probally caused by a jam forcing cutters apart and breaking housing inside.
Posted on Apr 01, 2008
  • Jared Gates
    Jared Gates Apr 07, 2008
    I apologize I thought I had already given you our cotact info on another posting. You will need to contact Fellowes at 1-800-945-4545 to check on parts or possible warranty info.
4 Suggested Answers
SOURCE: Shredder number ps60c
There is another screw hidden behind the bar code label. Slide your finger along the label while pushing end you will find the indentation. This was probably done to detect users opening the case and to void the warranty.
SOURCE: Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Posted on Mar 16, 2010
1alexh
  • 484 Answers
SOURCE: mY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Posted on Apr 22, 2010
How do i take the cover off a ps60c-2 fellows shredder?
Sometimes they hide another screw under the label. Try running your finger over the label and see if you can find a small dent, if you find one, then that is where the other screw is located.
Jul 24, 2014 | Fellowes PS60C-2 Shredder
Mar 13, 2010 | Fellowes Office Equipment & Supplies
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
Spare parts available PS60C-2
I need to replace one of the smaller nylon gears on my PS60C-2 Shredder. Would be interested to know if this is still available.
Thanks
Oct 07, 2008 | Fellowes PS60C-2 Shredder
Fellows ps60c-2
I have the exact same problem. Please share what you find I would be very grateful. Thank you, jmlaatsch@gmail.com
Mar 31, 2008 | Office Equipment & Supplies
Shredder ps60c-2
There are usually one or two hidden screws under the stickers.
Shredder
your best bet will be to call Fellowes at 1-800-945-4545 we will be more than happy to assist you.
Mar 30, 2008 | Office Equipment & Supplies
There's a 7th screw under the sticker!
Mar 29, 2008 | Fellowes PS60C-2 Shredder
Fellowes PS60C-2 Shredder Logo
970 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
