One computer on network can't open internet pages
Hey - hoping I can get some ideas...
I have a wireless network in my home using a Linksys using a WRT300N router. My HP Desktop computer that is connected to the router both by cable and wirelessly suddenly can no longer access the internet although it's logged onto tyhe network. I have two other computers that connected wirelessly and they are having no trouble.
The desktop with the issue has a NETGEAR WG311v3 802.11g wireless card. I have tried both IE and Firefox and am unable to open any internet sites. I just get errors that the page could not be found errors.
What am I missing? Any thoughts would be appreciated,
    Problem Solver:
  • 21 Answers
Have you change something in the web utility of WRT300N router. If not then I suggest take the wireless card out of you computer and reboot it. Try to configure your network connectivity through ethernet card, which is comparatively easy as to configure wireless network.
Run the disc that came your router and configure your network connectivity through its utility. Once you established network then you can try connecting wireless card back into your computer and take it from there.
Posted on Apr 01, 2008
    Genius:
  • 1,027 Answers
Try resetting the modem. It may be the Modem has to re-assign an appropriate ip address to your desktop.
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
No wireless connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 27, 2010 | Linksys WRT160N Wireless Router
I am unable to set up my Linksys WRT150N router security. I am using a Mac Computer OS X v10.5.8. I can access the internet using the router but only through an unsecure connection. When I go to change the...
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Jan 24, 2010 | Linksys Wireless-N WRT150N Router
I just bought a WUSB54GC v3 adapter and went through the setup. Everything said it was successful and was able to connect to the network. When I opened an IE browser, it said page cannot be displayed. I...
check the IP address on your computer. There might be a static IP address on the computer. You said that your other computer is online wireless. Open the router set up page and check the wireless settigns of the router.
Click Here to know more about the routers and network
Jan 19, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Hey, need help here. Got linksys wireless-g
the great thing about the linksys brand is that they are owned by cisco and they will walk you thru the set up no matter when and where you bought that thing and they will spend all the time it takes to make you happy with the product. although the person you speak to will be in "new deli" india so they may need to repeat them selves many times.
have you tried access the router interface page with the computer hook directly to the router NOT wirelessly.???
I think I remember the linksys access page is at 10.10.10.100 in your internet explorer tool bar.
Jun 13, 2009 | Linksys Wireless-G Broadband Router
Wrt310n adding wireless laptop
If you are using windows xp :
Go to Start>control panel> Network and internet> network connections > right click on wireless network > select 'view available wireless networks' and select your home network and click connect. If it asks for a password i guess u have it or if u dont have then go to Internet Explorerand and type 192.168.1.1 in the address bar, it will ask for a username and a password, type admin as username and the same for password. it will take you to the lynksys page....then select wireless and click wireless security, it will show you the wireless password.......
If u have windows vista :
Click Start > go to 'connect to' > select the wireless network you want to connect to and the rest is the same as windows xp....
Hope this works out
Regards,
Anup
Apr 07, 2009 | Linksys WRT160N Wireless Router
Internet connection shows good bars but can't connect to web
first, can you please tell me if what OS are you using?
: if its VISTA or XP, please remove the network profile in your laptop ...
then search again for the network ... by the way what router are you using ? if its linksys please update this thread so that i can assist you if there is a need to reconfigure.
goodluck
Nov 25, 2008 | Linksys WUSB100 Wireless Adapter
Linksys Wireless not able to connect to internet
Try it with Mozilla Firefox. If it works try some searches with IE, Windows ME and wireless as search terms.
Jul 09, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
