First wash the lint filter with dish soap and give it a gentle scrub with a plastic pot brush. Fabric softener can gum them up and impede the air flow.
Check the hose at the back for lint build up in the hose itself and in the tube at the back of the dryer. Finally check the flaps on the wall vent for smooth operation and they they are opening fully. If you have the old type with a circular flap, you might even find a birds nest in there!
Although the error light is telling you to clean the lint filter, it is actually registering reduced air flow and an overheat situation.
If you use fabric softener sheets in your dryer, they eventually will deposit enough residue in your lint trap to close up the mesh. Usually you cannot see the residue, although it is blocking the movement of air through it. My advise would be to remove the lint trap and run it under hot water and clean it well, then try the dryer with the clean lint trap. I hope this works for you and solves your problem.
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
An E1 Code is a thermistor fault
TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Error codes. are any of these lit?
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
E1 Thermistor open Replace thermistor if found defective
E2 Thermistor shorted Replace thermistor if found defective
