Wireless Network Detecting Problem
Hi friends, I have a strange problem. I'm using Windows Vista pc with D-Link router via cable modem. I have Toshiba laptop that was working wirelessly with this system. I went abroad and came back but now my laptop detects all the networks in range except mine. Though on the same router other laptops work perfectly alright. I don't know what's wrong but my laptop is not detecting my network but all other networks in range. Plzzzzz help. cheers
    Scholar:
  • 178 Answers
Check the channel reception of your laptop wireless card or try changing the channel on your router.
Posted on Apr 02, 2008
SOURCE:
What should be the "properties" settings for wireless network
If you have a wireless router and you want to setup a wireless network so your computers can share data between computers and access the Internet via a DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 16, 2012 | Toshiba Portege 2000 Notebook
I upgraded my toshiba NB200 from XP to Vista, but can no longer connect to the internet. Diagnostics is telling me that the computer does not have a wireless network adapter installed. It worked on XP....
Use an Ethernet cable to connect the LAN port on the Toshiba to your cable-modem (or DSL-modem) or to your home-router.
Then, run 'Windows Update', and look for "Optional Hardware" updates, which should include the correct device-driver for the wireless adapter.
Jun 15, 2011 | Computers & Internet
Just purchased a WGR614 wireless router for my dell laptop. the instruction manual only mentions connecting to external modem, what if you have a laptop with an internal modem, how do you connect? My...
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
Mar 23, 2011 | NetGear WGR614 Wireless Router
Running the wizard from the install CD does not find the router and I know the router.modem cables are connected properly... whats next...
It seems you're setting up a wireless network thru your router. The basic steps in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. As of the moment, we need to use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows.
Click the link below for proper cable connections in setting up your wireless network. This also provides somewhat a checklist on what you need for wireless connectivity.
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Feb 12, 2011 | Linksys E3000 Wireless Router
Pleasssssssssse help : on router G624T
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
I'm installing an old D-link DI 634M a friend gave me. when I have it all set with the e-net cable coming from my cable modem, I can access the web by logging in over the wireless part of the D-link (with...
You said you can get connection coming from modem directly? Or did you mean the modem is going into the wan port of the router?
Did you try all the ports on the router?
Did you check the cable?
Did you try turning off the wireless on your the pc and connecting via e-net cable?
Make sure it is not the pc or cable.
Also, check and make sure a firewall is not waiting for you to add it to the trusted sites list.
Are you getting an IP when you plug in the cable and are the lights lit up on the router and nic?
I would make sure you got a connection to those ports via another computer before moving on, and try using all the ports with a different cable if possible.
Oct 04, 2009 | D-Link DI-634M Wireless Router (DI634M)
Connecting a router
To connect more than one computer to same network, you need to use a router. Two modems will not work on same network.
My suggestion:
Buy a wireless modem router for cable broadband (and eventually a wireless network card for the other computer.
Here is an example: Linksys BEFW11S4 Wireless-B 4-Port Cable/DSL
Ask retailer to get right model for your broadband.
Connect the remote computer with wireless.
Apr 22, 2008 | Computers & Internet
Windows Vista to a Wireless DI-624 problems
I have a Toshiba Satellite connected to a Di-624m and I have the same problem.
One solution to many problems with D-Link is to ;
UNPLUG BOTH MODEM AND D-LINK.
WAIT 20 SECONDS (TWENTY SECONDS)
PLUG BACK IN AND TRY TO CONNECT.
DO NOT JUST SHUT THE POWER OFF, IT IS NOT THE SAME!
IF YOU DONT UNPLUG LONG ENOUGH IT WILL NOT WORK.
RECCOMENDATIONS:
CONNECT DIRECT WITH A LAN CABLE TO D-LINK
EVEN BETTER
CONNECT TO YOUR MODEM WITH A LAN OR USB-VERY FAST.
REPLACE THE D-LINK HUB! (LESS THAN A $100 !?!?!?)
WARNINGS-
OUR D-LINK ROUTER HAS CAUSED PROBLEMS FOR THE PAST YEAR ON OUR NETWORK, SOME OF THESE PROBLEMS WE BLAMED ON VISTA.
This wireless enviroment can corrupt downloads.
I went crazy trying to solve several download errors.
connecting direct to the hub with a lan cable solved the problem.
I have totally lost faith in this wireless system.
sorry D-link the di-264m is HISTORY soon.!
haydenshaw3
Apr 17, 2008 | D-Link Wireless
New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Jan 08, 2008 | Trendware TEW-432BRP Wireless Router...
Open Questions:
Computers & Internet Logo
158 people viewed this question
Ekse
Alun Cox
