Question about Kenmore 72982 Gas Dryer
Not heating I think the heating element is broken.
  • robert samples May 11, 2010
    first thing to check is your power and dont say well it runs they will run on 110 but not heat
    Novelist:
  • 142 Answers
You should be able to test the elements with an ohmmeter. With all the power off and the unit unplugged, disconnect the wires to the elements and place the ohmmeter across the elements. You should read less than 10 ohms on all elements. If you read an open circuit across the elements then the element is gone.
Remember the elements cycle on and off during the drying cycle. Have a look at the thermostat section and thermal overload switch. Make sure they are OK. The thermal switch should be zero ohms with a cool unit. If you're not able to perform these tests, consider a repair shop. They can do the diagnostics within a few minutes and let you know the cost of the repair. Then the decision is yours.
Posted on Apr 02, 2008
    President:
  • 1,314 Answers
Excuse me i didn't notice the gas part most common is the ligniteri think i need a break
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
HIs it possible to change the heating element. I'm convinced that mine is broken. How do i replace the element?
It will help if you provide the make and model number of the dishwasher. Also it will be useful to know why you think the heating element is faulty.
Dec 12, 2010 | Dishwashers
I think the heating element is broken. We have had it 12 years and it is shrinking clothing on the low setting.
Actually, it's most likely that your thermostat is faulty. This is the part that cuts power to the element when the dryer reaches the correct temperature. Heating elements generally DON'T heat when they develop a fault - they burn out.
I can't give you the part number or fitting instructions as you did not specify any brand or model.
Hope this helps.
Oct 21, 2010 | Dryers
Where can i basic tips to care for my dishwasher? The cycle runs but there is still spots and dirt on the dishes. Do not think it is broken Thanks
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Frigidaire 24 in. FDB635RF Built-in...
The iron does not heat up
Hi.
Either wiring is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
Jan 15, 2010 | Steam Fast Irons
The dryer will not heat. Think the heating element is bad. Where is it located on the dryer?
it is located at the back of the drum inside an oval housing. if the element coil is not broken, you may need the thermal cut off kit which is part #3977393, it contains 2 thermostats. the element part #is 3403585. hope this helps.
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
Hello there:
I would have to tell you that i dont think that the two would fail at the same time but it can happen but not too often
deffinatly replacethe timer and the heating element and this will solve the problem
also since you have the unit opened i would inspect all of the wiring for loose connections and moisture cause this will cause things like these to fail prematuraly ok?
I hope that this has peeb very helpfull for you
best regards michael
Nov 04, 2009 | Kenmore 659 Electric Dryer
Blanco oven not heating
simple is simple as, replace the element!
Oct 08, 2009 | Ovens
Dishes come out all wet. Maybe the heating element but would there be any other potential?
You are right -almost-. When the heating element is not working properly and dishes doesn't dry, I don't think the heating element went bad. It's more likely that other part is causing the problem. Perhaps the timer went bad.
When the timer is broken, the heating element doesn't get power to dry the dishes. By the way, the timer are also called electronic controls or control panel. I believe it needs to be replaced.
Aug 29, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dryer runs, but there is not ant heat.
hi,
Sounds like your element went. Unplug and take off the back. You will see a grey or silver rectangular box with red wires coming out of the bottom, this is your element box. remove the element box and the wires that go to it. put the box on the counter. the element array comes out of the metal box with a couple more screws on the box. Study the element array for the broken element, you should see it. Call the appliance parts store or take it in to them and I think the element was pretty inexpensive (30.) good luck
J
J
Aug 15, 2009 | Whirlpool Dryers
Kenmore 72982 Gas Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
