Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Wiring low voltage
Can someone please give me a step by step procedure on wiring my honeywell HE22OA humidifier. I am not clear how to do this. I have a plug in transformer, humidistat, sail switch and solinoid. Thank you
  • wpturner2 Jan 04, 2009
    I need detailed wiring instructions for honeywell he220a1019 whole house humidifier
  • Anonymous Mar 15, 2014
    white wire to humidisat white wire to humitifier coming from transformer and one red wire from humidistat to humitifier wont work automaticlly, but if you turn the knob of humidistat well work HE 120 whats wrong with this picture help me with this matter thanks
Trying to find wiring instructions for honeywell he220a1019 whole house humidifier.
Posted on Nov 18, 2008
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
I have a HE265Ahumidifier it keep burning out transformer whats wrong
Hello, usually the transformer will burn up when the amp rating of the transformer is being exceded or if there is a short in the low voltage wiring
Dec 09, 2011 | Honeywell HE360A1027 Whole House...
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
Connecting an Aprilaire 700M to my HVAC system. I do not have the wiring diagram for the fan control board for the HVAC system. Aprilaire diagram says to wire the 120VAC to 24 VDC transformer to the HVAC...
If you don't have a volt meter, purchase one. I've seen them as low as $20.00 at Sears and even lower at Home Depot and other discount stores. The HUM terminals are most likely low voltage (24v). The "N" is the neutral. Assuming you have confirmed this is low voltage (24v, you will use HUM and "N" terminals. This control sequence is typically to allow for operation of your humidifier only when there is a call for your fan to run. The brown wires coming from your Humidifier are your low voltage circuit. One should be directly wired to "N". The other should be ran to your humidistat. The other side of the switch of your humidistat should be wired to the HUM terminal.
I hope you will find this helpful. Good Luck!!!!
Feb 06, 2010 | Aprilaire 700 Humidifier
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
My air king humidifier won't shut off
This might have a bad valve,or It could be mis-wired.It should be wired to common and hum on the control board.You can test By checking the voltage when the unit is off,and valve should be closed. Good Luck --Nate
Oct 29, 2009 | Honeywell HE360A1027 Whole House...
Honeywell TrueStream Humidifier issue
there is a bank of dip switches to the left of the low voltage connections almos middle of humidifer on the green control board the numbers are clearly above the switches
Apr 06, 2009 | Humidifiers
HE220A direct wiring to protech 62-24084 control board
it is best to use a seperate transformer for the hummidifier, but in some cases you can use the low voltage t-stat wire that runs your furnace, you will need to have one wire run to common, and the other to the heating side of your low voltage, normally its the red wire hooked to the w circuit of your terminal board, if you do decide to go with an extra transformer, make sure you you have it wired to bring on the humidifier only when the unit calls for heat, hope that helps
Jan 19, 2009 | Honeywell HE260A1010 Whole House...
Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Jan 28, 2007 | Honeywell HE360A1027 Whole House...
Humidifier intermittently won't shut off with blower
THAT MODEL COMES WITH A BUILT-IN AIR FLOW SWITCH (IF I RECALL CORRECTLY) THAT CAN GO BAD ... IN THE OLD DAYS WE JUST POWERED THE HUMIDIFIER BY CONNECTING IT TO THE LOW SPEED (FOR HEAT) OF THE BLOWER MOTOR. HONEYWELL HAS HAD PROBLEMS WITH THEIR RESIDENTIAL AIR-FLO SWITCHES ON HUMIDIFIERS AND THEIR ELECTRONIC AIR CLEANERS. AND THEY ARE THE HIGHEST PRICED ON THE MARKET.
Oct 27, 2006 | Honeywell HE360A1027 Whole House...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
598 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
