Connected my mac mini with RGB and got desktop showing. Tried to change resolution and now all I get is a no signal message. When I connect my mac book I have no problem. Any ideas? please
  • tony907 Apr 01, 2008
    sorry! forgot to mention, connected it to 42"LG TV
  • 76 Answers
Ok first chenge resolution 800/600 your problem solove
Posted on Apr 02, 2008
OK, mini display port to VGA adapter-is the VGA cord the one that goes into the port labeled RGB and audio on the back of the Samsung? Sorry to be a dummy but Samsung monitor is 6 years old and has always...
An RGB port is for a component cable not a VGA cable. A VGA cable, similar to a component cable, only carries a video signal but is a 15 pin cable that nearly all monitors and HDTVs support. Most laptops have a VGA out port.
You should be able to connect your laptop to almost any monitor (not sure about your Samsung) with a male to male VGA cable.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Computers & Internet
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
My LG tv shows no signal with hdmi cable to hp
First you need to state Mac G5 model and MacOS 10.?,? and whether the connection is VGA or mini-DVI. (I'm at 10.5.8.) I would not be helped by LG model other than to know if it is HD 1080 or 720. I'm going to assume you have MacOS 10.4 or later but most should apply. Apple>>About This Mac>>More info...>>Hardware>>Graphics/Display and read more about the display. Digital connection will give you more info. Close the Info but even with VGA you should be able to go to Apple>>System Preferences...>>Displays and have 2 windows--1 for the built-in and 1 for the external. If the latter is off screen, press Gather Windows. On the external display Turn on Show Displays in Menu Bar. This will let you control Mirroring and Resolution. You will need to pick a resolution your TV can do 1920x1080 1280x720 or possibly less to get started. My MacBook has all of those. I usually do not use mirroring and 1920x1080 gives a good pixel match to my DLP. On the external, turn on overscan if you need to put the menu bar on the screen or off if showing maximum of photos. You need to sync first, then play with other things. -Ken
Aug 20, 2009 | Apple iMac G5 Desktop
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Mac mini and Planar PL2010MW contectivity
have you tried changing the display resolution to lower at first so you can at least get a signal ?
Dec 27, 2008 | Planar PL2010MW Monitor
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
May 20, 2008 | Televison & Video
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
