Z-5450 subwoofer not working
I am in a very mood now..
I bought a z-5450 speaker, then it broke about a month later.
I think the problem is the subwoofer, because only the front speakers do not provide any sound, but wireless ones on the behind do.
I asked logitech, and they said they cannot replace it because my warranty is outdated, they cannot fix it because there is no such service, and there is no way i can buy only the subwoofer.
Is there a way I could fix this, or at least purchase the subwoofer?
    New Friend:
Hello! Change the 2 capacitors 100uF 10V on the power card on the rear speakers. The capacitors are laying side by side on the printed circuit where the 220 V transformer is fitted. I used 100uF 16V on my speakers. The flashing red LED changed immediately to steady blue.
Posted on Jan 07, 2010
Deal with it
Posted on Apr 01, 2008
6ya staff
SOURCE:
Z-5450 rear wireless speaker not work always red light flashing
Hello have you been able to fix the problem. Do you still have the speakers?
Sep 12, 2011 | Logitech Z-5450 Computer Speakers
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
I'm getting no sound from my htr-5450 reciever
Check the "speaker selector" on the front panel. Make sure A, B, or both are lit up. Also, make sure the "6 ch input" is"off" it's a button right below the volume knob on the right If it's still not working, post a comment and I'll help you troubleshoot further. Hope this helps
Jun 30, 2009 | Yamaha HTR-5450 Receiver
Energy S 8.3 Woofer; blue led doesen't light up
Bought a S10.3 in jan/2010, LED died a month later. I've repaired it by myself. After inspecting circuit, I've found that their design puts almost 14V of reverse bias upon that poor blue LED. These components are not usually expected to sustain more than 5V of reverse polarization. So, in my opinion, there is a design flaw. To make a long lasting repair, you just need to insert a general purpose diode in series with the LED, such as an inexpensive 1N4148 ($0.05). And, of course, any readily available 3V, 5mm, through-hole round blue LED (I think crystal clear should be better).
Sep 09, 2008 | Energry Speakers Energy Speakers S8.3...
Subwoofer problem
I have the same problem. I tried to get it fixed by sending it to my retailer (Best Buy) who then sent it to the LG company and they said everything was fine. But there was one problem with their diagnostic...it wasn't. The subwoofer worked fine when i originally bought it, but about a month later it would not work or it would work intermittently. It literally takes about an hour for this thing to start working, and now my right speaker has started to not work. My judgment is that this product is poorly made and the service people at LG are incompetent!
Aug 07, 2008 | LG LHT734 System
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
634 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
