Question about Audiovox D1812 Portable DVD Player
Audiovox D1812 disc loads & plays but VERY dim screen
The brightness control will black the screen all the way, but turned all the way up the image is barely viable.Any ideas would be helpful. Jay
  • Anonymous Aug 09, 2008
    Same problem, sounds ok, but very drk screen all of a sudden. very disappointing for an 18 mo. old player........would love a solution. Also have a 5" Audiovox that woks, wonder if parts are interchangable??
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Posted on Jul 22, 2008
  • budgiegirl Apr 19, 2011
    or u can click the setup button and click the video setup page and u will find wat u need there
SOURCE:
Black TV screen: no image, just sound
Sounds like the brightness might have been turned down. Does it have a manual brightness control? Sometimes there is a combination of buttons you can push on the remote to reset the TV to factory specs. Add some more info about the TV, Make, Model #
Feb 17, 2014 | Televison & Video
Player stays in loading mode never finishing and playing the dvd
see the causes and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Clean with disk cleaner the Lens +OPU
Jul 21, 2012 | Audiovox D1812 Portable DVD Player
Audoviox D1812 wont load dvd..
try to manually clean the lens of the player.open the cover and using a cotton buds moistened with an alcohol,gently wipe the lens to remove the dust accumulation.be sure to unplug the unit before cleaning.
Jun 06, 2012 | Audiovox Televison & Video
Screen is backlit; however, dvd does not load/play/spin.
Hi, There is some DIY steps that may help you fixing the problem. Click the link http://www.fixya.com/support/r7833671-change_defective_motor_portable_dvd. I've suspect that you're motor is faulty since the disc is not spinning.
Hope it may help you. Have a nice day!
JDVillanueva
Feb 05, 2011 | Audiovox D1812 Portable DVD Player
Disc not playing?
what error it is showning on the screen?
Apr 24, 2010 | Audiovox D1812 Portable DVD Player
Audiovox D1812 Portable DVD player won't recognize disc
I have the same model, exhibiting the same problems. I bought it in 2005, and have used it only on trips. I bought mine at Sam's club and I emailed them and Audiovox and have gotten no response. It says little of Sam's Club or of AudioVox!
Sep 29, 2007 | Audiovox D1812 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Audiovox D1812 Portable DVD Player Logo
147 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
