Question about iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba runs in circles - iRobot Roomba 4210 Bagless Robotic Vacuum
  • Anonymous Apr 20, 2008
    mine goes in circles also. i note that one of the wheels doesn't turn as well as the other, so that explains the circles i guess, but not the problem. i've blown out the entire wheel assembly with compressed air and put it back together, but no improvement
    Problem Solver:
  • 7 Answers
Try using a leaf blower, up close and all around. I was having problems with (I assume) the sensors under the bumper and (maybe) the wheel sensors, but after blowing it out with a leaf blower it works fine.
Posted on Sep 14, 2008
4 Suggested Answers
SOURCE:
  • 66 Answers
SOURCE: The Roomba goes around in circles. If it
Are you sure it is 10 beeps ?
look in your user's manual, the beeps code is there with some
suggestions how to solve it
Have fun
Avi
Posted on Apr 12, 2010
SOURCE: roomba red #4100 needs repair does the circle
sounds like you have two different issues here. (Possibly one common)
Clean out the cliff sensors. Under the bumper. blow it out clean. This might stop the reverse circling. The battery is either bad, or the charging circuit is bad. if battery is know good then the problem is the main board needs to be replaced. a bad battery will kill a main boards charging circuit by over working it with shorted batteries
Posted on Jul 24, 2010
SOURCE: Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Posted on Oct 16, 2010
Roomba just turns in circles what could be wrong
What to do when the Roomba just goes in circles ' All about Roomba ...
https://roombafan.wordpress.com/2015/05/17/roomba-just-goes-in-circles/
May 17, 2015 - Single beep - Roomba is stuck or wheel is hanging down; you need to move your Rhoomba to a new location or check the wheels. Two beeps - this happens when the main brushes become immovable, so you need to check the brushes. Six beeps - the likely cause is a dirty cliff sensor or the robot is stuck on a cliff.
Roomba is backing up and circling. - Find Answers ' iRobot Customer ...
https://homesupport.irobot.com/app/answers/.../roomba-is-backing-up-and-circling. If Roomba backs up or spins in circles, run Roomba in an open area with no obstacles present for 2 minutes to determine if the robot will stop with an error ...
SOLVED: The Roomba just goes in circles, how do I fix this ...
https://www.ifixit.com/.../The+Roomba+just+goes+in+circles%2C+how+do+I+fix+this Oct 23, 2016 - Dirt and debris can cover the sensors and make the roomba believe it is ... When my Roomba turns on, it will only spin around in circles and ... Won't go straight; not circle of *****
May 30, 2016
Vacuum will not go straight
May 7, 2013
SOLVED: roomba 560 got wet and now it doesnt go forward ...
May 15, 2012
SOLVED: When I turn my Roomba on, it doesn't go forward ...
Apr. 25, 2011
More results from www.ifixit.com
iRobot Roomba circle dance - "fix" - YouTube
? 5:37
https://www.youtube.com/watch?v=sN03AWr1VAk Jan 21, 2008 - Uploaded by Scubaholic
Didn't feel like open my roomba at 10pm, so I just sprayed it with some canned air around the wheels and ...
Help! My Roomba goes in circles! - Robotic Vacs
https://robotic-vacs.com/2016/03/03/help-my-roomba-goes-in-circles/ Mar 3, 2016 - What to do if your Roomba just goes in circles. Roomba goes in circles. No, your Roomba doesn't have a mind of it's own, nor is it tipsy from ...
May 20, 2018 | Roomba Vacuums
Goes around in a circle and won't go forward was working fine untill my husband cleaned it out with tweesers
sounds like one of the motors on the wheels stop working making it go around in circle and not forward
Feb 16, 2011 | Roomba Vacuums
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in circles. appears lost
You have a locked wheel switch that needs to be cleared. You will need to remove the top of your roomba and find which wheel switch is clogged and clear it.
Mar 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in circles then stops and blinks power indicator
Actually, this is the Circle Dance Error. You can find a fix for it here or if you want more information about the Roomba Circle Dance Error.
Dec 21, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba 530 runs in a circle and does not move forward. After 2 minutes it stops with 11 beeps and a flashing red light to the left of the power button. It has no clicking noise. Does anyone know what is...
Hey'
This means Roomba is not registering obstacles. Roomba may be stuck in one place.
Roomba may be in extremely large room, try setting up virtual walls to create smaller area.
If Roomba is not in a large room, tap Roomba's bumper to confirm it is properly working.
Hope this helps
Avi
Nov 09, 2009 | Roomba Robotic Floor Bagless Vacuum
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My Roomba 560 has started to run in small steps as if it constantly meets an obstacle and turns around in a very small circle. It advances slightly, backs slightly and turns and then does this again and...
It probably does think its met an obstacle. It could be the bump sensor switch remains pressed, one of the 4 cliff sensors on the front is dirty, or one of the 3 wheel drop sensors (left right and caster) is alarmed. Clean the sensors and your problem may resolve.
Oct 04, 2009 | iRobot Roomba 560 Robotic Vacuum
Running backwards in circles.
If your Roomba's speaker isn't working, you need a new Roomba regardless. Give a call to customer support (877-855-8593) and they'll help you out.
Jun 10, 2009 | iRobot 4150 Roomba Vacuum
My roomba now just spins in circles in one spot. it does not go anywhere.
Try blowing out your bumper with compressed air. Tap the bumper with your hand to knock loose any obstructions. Then run your Roomba. If the behavior persists, the best way to resolve it is to call customer support. (The number should be in your documentation or on the bottom of the robot.)
Fembot
May 02, 2009 | iRobot Roomba 560 Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
473 people viewed this question
Top iRobot Vacuums Experts
Oliver Street
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
