My psc 2210 stopped being able to accept memory when I tried to send a fax that was too many pages. Now I can't scan or fax anything with it. Is there some way to clear the memory and get it to scan/fax again.
    Genius:
  • 3,422 Answers
HI,
The only solution to fix your problem is to restore it to factory defaults:
You can perform this process from the front panel only.
) Press Setup.
2)Press 5, then press 3.
This selects Maintenance, and then selects Restore Factory Defaults.
The factory default settings are restored.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 01, 2008
How do i use my scanner for hp psc 2210 series.... I trying to scan something. I have pushed the scan botton on the printer. And i can't scan anything.....
The reason may be that the software is not installed properly. Did you try to scan from computer?
From computer you can try from Hp Director/ HP Solution Center or from scanner and camera wizard.
Mar 29, 2011 | HP PSC 2210 All-In-One InkJet Printer
What does NG mean for Status after sending a scanned item or faxed item?
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
Thanks.
Jun 25, 2009 | Toshiba e-Studio237 Grayscale Copier
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
Sending fax
Iam afraid HP Supports VOIP Services, they always says that we do not assure fax in VOIP Service because it is not analog it is digital they always refer to your service provider
Also you can tried reducing the speed of the fax machine
That is> Press Menu/Setup> then scroll toAdvance Fax setup> Then Fax Speed> then Press Ok> And reduce the speed to Slow and then try.
Good Luck
Jun 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Trying to scan a picture
if your using the "scan" button on the panel of the computer it wont work, in order for the button to work you need to install the software.
if your trying to scan from the pc and you cant scan, try these:
1. right click on the solution center icon on your desktop
2. go to properties
3. click on open file location
4. search for hpscnvw.exe
5. right click on that application then send to desktop
6. now when it is on your desktop, use and click on that icon everytime you want to scan
Jun 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
My hp psc 2210 stopped being able to take any memory when I was trying to send a fax. I not only couldn't send the fax, but now I don't know how to clear the memory so I can use the machine. It simply...
My hp psc 2210 stopped being able to take any memory when I was trying to send a fax. I not only couldn't send the fax, but now I don't know how to clear the memory so I can use the machine. It simply said "memory full" at some point and then wouldn't work anymore. Can I clear the memory and get it functional? Mike Berry
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
Apr 01, 2008 | HP Office Equipment & Supplies
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cannot receive fax
1st is the LINE and second is to connect the telephone.
To send and receive fax, u must connect the line into the first jack.
Dec 26, 2007 | HP PSC 2210 All-In-One InkJet Printer
64 people viewed this question
jasbo
jasbo
