Question about Sansui VRDVD4005 DVD Player/VCR
Loses programing when I get a power-outage recorder loses its programing. does this mean unit has no builtin battery back-up, or does it not have one ? kelly dow
    Genius:
  • 1,139 Answers
It has a microprocessor that is supposed to keep the settings. What is happening is that the microprocessor is not holding the configuration, or the configuration is not being saved as it should be. This could indicate a bad microprocessor or a failed state maintainer circuit. In both cases I would suggest that you take you unit to a qualified electronics repair shop.
I hope this helps,
Shuttle83
Posted on Apr 23, 2008
Battery Back-Up not coming back on after power outage. Charged for several days without anything plugged in with trip button pushed in. Surge side still working. No beep light or anything on battery...
Does the unit have a breaker on the back? There may also be a fuse. You should be able to find a users guide on the CyberPower website.
If the unit may have failed during the power outage.
Jan 07, 2013 | CyberPower Computers & Internet
Sony CDP-CX450 Cd Player
As in most current devices, absence of power (as in shortages/outages) simulates a reset. The reset reverts the unit back to factory defaults which of course does not have user configurations and settings.
A workaround perhaps would be with the use of a UPS as those used in computer systems.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Sony CDP-CX450 400-Disc CD Changer
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
We seemed to have a power outage over the weekend. We have M7324 system with 6 rollover lines, only the first two work now, the other four are not working. I rebooted the system, no change. Can you help?
You must have an older system. There is a battery built into the control unit (not user replaceable) that stores the system programming in case of a power outage. When the battery is dead, your system will lose all programming and default to assigning the first 2 lines to all phones. The system will have to be completely reprogrammed.
Please Note: Now would be a good time to install a UPS/Battery Backup unit on the phone system. I recommend a large enough unit to keep the phones running for at minimum of 2 hours during a power outage. Install the UPS/BB first, and then reprogram the system (so it won't have to be reprogrammed twice). Good Luck!
Aug 02, 2010 | NorStar M7324 Corded Phone
Power outage. Lost all programs and not able to record.
Hi jollycay there is something else you can look at, youwant to press the Menu button and then press the numbers 6-1-3. It will takeyou to System Info 1, you will need to see if field F is green and if so I do apologizefor the loss of the recordings due to we have no way of recovering them. If thebox is not green please call in so we can take further action.
Mike Houston of DISH Network
May 11, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Back UPS Model # BK200C salvageable?
Yes you right you can just use it as surge protector, but it would be better if you gonna buy a battery for that unit aleast you got a back up in the event of power outage.
Jan 27, 2009 | APC Back-UPS 200 UPS System
When prompted I can't leave a message in any mailbox.
Having to reprogram the system every time has nothing to do with the voicemail. The battery in the preocessor is bad, and not holding the programming telling the phone system where the vociemail is.
The partenr mail VS might be going bad. You can try to reset it, but then the system loses programming.
Dec 26, 2008 | Avaya Lucent Partner 616 Phone
Problem with AVAYA ACS R 7.
Parviz3,
This unit sounds like it is like a computer that loads the program everytime it is turned on. When I am working on HD Video and I don't want to loose all the work I have been currently working on due to power outages, I put a UPS Battery Back up system on it that is capable of keeping my computer on for at least 30 minutes while things are being worked out.
This would be my suggestion for you. Buy an independant Battery back up power supply unit from a local store and be sure to get a medium sized one. I assume this phone system uses very little amperage and with such a battery back up system would stay on for days when your power is out. That would be the easiest solution and less time consuming for anyone at this point.
Dec 14, 2008 | Lands Phones
Sansui vrdvd4005 combo vhs/dvdrecorder
Most do not have a battery backup, they just have a capacitor that will keep stored data alive for a few seconds in case the power blinks.
Hope that helped...
Geno
Apr 02, 2008 | Sansui VRDVD4005 DVD Player/VCR
Onkyo Forgets it's input settings during power outages
yes there is ,,, it is located on the same board that has 3 fuses on it, you will have to unplug the unit before disassembly, and remove the top cove and bottow covers,,,, you will have to de-solder a small battery pack surrounded by either blue or yellow heat shrink,,, please not the polarity before removal, as putting it in wrong will cause a non- memory retaining situation to continue...I hope this helps
Jul 07, 2007 | Onkyo TX-DS787 Receiver
Sansui VRDVD4005 DVD Player/VCR Logo
52 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
