Question about Vizio L37 Television
VIZIO L37 I replaced the entire power supply board #0500-0502-0121 still does the same thing.So now replacing both the main board(3370-0082-0150] an the power supply I dont really know of anything else to get.I dont want to keep spending more money on it.What do you think?Do you think I should just forget about?It no longer has a warranty either.Thanks pcrane1..
  • pcrane1 Apr 02, 2008
    thanks for your help i will do that.
Can I buy the parts you change out?
Posted on Jun 09, 2008
  • 3,037 Answers
If anything, try taking it to a tv repair shop and see if they can find something wrong with it by looking at it which I am physically unable to do online. See if they can look at it free and tell them what you have replaced but I don't know what else without looking at it myself. I hope you get it working.
I doubt you can get a free inspection of it but you can try. Possibly let them know how much money you have spent already and maybe they will give a little leeway. Good luck.
Posted on Apr 02, 2008
Vizio E601i-A3E (no power). I have replaced main power board and entire power cord assembly. Anything else i should be looking at?
The main board sends the on/ off signal to the power supply board. If a new power supply doesn't fix it, then the main board is faulty.
Aug 30, 2016 | Vizio Televison & Video
TV went blank bank and begin to make a very loud static and squealing sound. I unplugged the TV but the noise continued for about 30 seconds and then then nothing. We thought it was going to explode.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 19, 2014 | Vizio L37 Television
Cable port broken off vizio L37
The Main Board will need replacement. Soldering in another cable connector will usually not work in most cases unless you change the entire tuner
Aug 02, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
Have replaced power board and main board... still no picture..
you need to check and see if you have 24v from the power supply to the ballast if you do the problem is going to be the ballast ( inverter board ) bad capacitor
Feb 03, 2012 | Vizio L37 Television
37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Jan 16, 2010 | Vizio L37 Television
No picture power ups blacklights work no menu no
If you see the back light, then you should have 24vdc on the main power supply board which it gets the turn on command from the maun board. If you do have all those voltage, then it does sound like you need the new main board.
Nov 25, 2009 | Vizio L37 Television
Vizio TV (L37) will power up but no picture
The backlight is powered by its own supply (although it may receive input from the main supply) and it sounds like the main supply or one of its outputs has failed disabling the video and sound processing.
Dec 24, 2008 | Vizio L37 Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Vizio model L37
here, try the trouble shooting guide and let me know start with page 56, here is the link
Let me know when you have tried the trouble shooting for picture and sound even though this may not help, Also, since replacing the board didn't work, I will suggest going right to the manufacturer on this since the board was the only thing that really made sense for both to be out. Otherwise there might be a loose connection somewhere, anyway call them and let me know what they tell you and if they can't help, then you might have to take it in somewhere to have it checked, but the main board is the only thing that really makes sense
Main support number 714-668-0588
Email supporttechsupport@vinc.com
Mar 24, 2008 | Vizio L37 Television
Vizio L37 Television Logo
274 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
