Question about Samsung DVD-R130 DVD Recorder
Stuck in Safe mode
The dvd-r130 turns on and is in safe mode.
How do i take that off so we can use the machine?
  • Talaric Apr 29, 2008
    Yeah, i got the same problem. I've already posted as Talaric. i took the suggestion to turn it all off and then turn it back on and hold the open/close button for 10 seconds. Seemed like a good possibility but didn't work. So, if you have a solution for Candie, i'd be happy to try it as well.
  • 3 Answers
PRESS INFO BUTTON ON REMOTE FOR 5 SEC AND EVERYTHING WILL BE BACK 2 NORMAL
Posted on May 19, 2008
How do you Stop Safe mode,on the tablet?
Stop Safe mode on the tablet Google Search
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
Mar 07, 2018 | Tablets & eReaders
Stuck in safe mode
To begin with someone needs to open and look inside the unit to see if the disc is out of position or jammed, this could trigger the safe mode.
Dec 13, 2012 | Samsung DVD-V9650 Dvd / Vcr Combo Player...
Hola como esta quisiera saber como hago para programar mi DVD SAMSUNG R130 ya que me aparece con la palabra SAFE y no me deja hacer ninguna fucion le agradesco de antemano su colaboracion Att: Jorge...
Gracias Jorge Sanabria por darme la oportunidad de responder tu pregunta.
Chequiando el internet me doy cuenta de que el Samsung DVD-R130 DVD Recorder no es un producto que lo recomiendan por clientes .
Esta es la informacion que encontre. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc 3 de 10 compradores no recomiendan este producto. Mi opinion personal es de que si lo puedes regresar eso fuera lo ideal pero si no se puede asmelo saver y buscamos una solucion para este problema.
Si esto soluciona tu problema x favor as grado mi respuesta. gracias
============================ Thank you Jorge Sanabia because you give me the oportunity to answer your question.
Checking the internet I notice that Samsung DVD-R130 DVD Recorder is a product that is not recomended by the customers.
This is the information I found. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc
3/10 customers don't recomend this product.
In my personal opinon is that if you can return it, that will be the ideal but if you can't please let me know to find a solution to this problem.
If this solution solve the problem pleas grade my answer.
Tahnk you
Aug 15, 2010 | Samsung DVD-R130 DVD Recorder
Dvd-r130 write safe on front panel
sounds like child lock has been activated. most likely button on remote control ( look for c.lock, etc) sometimes power button, play button, stop button etc on remote needs to be held to release
good luck
Aug 10, 2010 | Samsung Televison & Video
Disc is stuck in the tray - samsung dvd R130
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
Mar 13, 2009 | Samsung DVD-R130 DVD Recorder
Stuck in safe mode
There is a botton on the remote (Lock) that puts in safe mode and off.
Dec 03, 2008 | GoVideo VR3845 DVD Recorder/VCR
Dvdvcr2 displaying SAFE
Hold down the "INFO" button on the remote for 5-10 seconds and this will clear the "SAFE" mode.
Jul 18, 2008 | Samsung DVD-R130 DVD Recorder
Samsung Dvd R130
THE WAY TO GET RID OF THE SAFE IS TO PUSH INFO ON YOUR REMOTE FOR 5 SEC AND WILL BE "SAFE" NO MORE
SERGIO
Mar 24, 2008 | Samsung DVD-R130 DVD Recorder
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Oct 29, 2007 | GoVideo DV2150 DVD Player/VCR
Safe mode
The safe mode on Sanyo VCRs locks out the buttons on the machine. Try using the remote. To turn off the safe mode, look for a button on the remote labeled "Safe."
Dec 31, 2006 | Sanyo DVW-6000 DVD Player/VCR
Samsung DVD-R130 DVD Recorder Logo
265 people viewed this question
Jerry Greenberg
Jerry Greenberg
