Proview PL926Bi Capacitors
Just curious what capacitors you switched out on your monitor?
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    I don't understand you question?
  • 186 Answers
Mine had about 6 blown capacitors. Just look for the ones with popped up tops to them - they will be weak/bad for sure.
Posted on Apr 23, 2008
TV will not turn on. It was turning on via switch at back, but now will not. Proview 19
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Oct 13, 2012 | Proview Televison & Video
My proview monitor stays on for 10 sec then goes black. but i can faintly see my page.
This indicates an inverter board failure, caused by bad capacitors that sometimes bulge at the top showing that they are open, an attempt can be made to repair or replace the board.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
On modern capacitors 2005 or up the capacitors can go bad and not even bulge at the top. I replaced a few in my moms flap panel monitor and found out that there were more that were bad and they didn't show any signs of damage but put your finger on one of those suckers and it burns like a smoking gun.
Apr 10, 2009 | Proview PL926WBi 19" LCD Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
19inc moniter power on then goes off within 1 sec
bad capacitors in the power circuit for the inverter power supply, replace these and everything should be alright it requires soldering skills or I can do it for a fee. It can also be transistors but much more likely it is capacitors.
Jan 12, 2009 | Proview PL926WBi 19" LCD Monitor
Proview monitor fix
I did it just because the higher voltage caps would give a lower heat dissipation thus leading to a longer life this time around.
Oct 17, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor
Proview known to have problems with failing capacitors in the power supply, not too hard to do for a few pounds worth of new caps. and a soldering iron.
Aug 31, 2008 | Proview PT 15.1" LCD Monitor
Proview 19# model PL926Wbi
thers Sounds like the problem I'm having /had exactly. When I opened the case I found that like others the 470mf capacitors on the power board had gone bad. (See the post from Delphiuser)
The capacitors are probably from a Chinese company called Xandu and I'm currently looking for a replacement capacitor to fit the circuit. Its a 470 mf cap with a 25 volt rating .
May 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 700p problem
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Computers & Internet Logo
433 people viewed this question
David Payne
David Payne
