Question about RCA HD52W59 HDTV Projection Television
MITSUBISHI MODEL NO. VS-5043 BOWED AT TOP AND BOTTOM.
HI , I HAVE A MITSUBISHI BIG SCREEN AND I HAD JUST REPAIRED THE COMMON THAT THEY HAVE WITH BAD CONNECTIONS ON THE YOKES.
THEN STATED TO TWEAK THE CONVERGENCE WITHIN THE SERVICE MENU. WHEN ALL OF A SUDDEN THE TOP AND BOTTOM OF THE PIX BOWED. PUZZLED.
COULD YOU HELP ME WITH THIS?
THANKING YOU IN ADVANCE.
BOOMBOOM
    Scholar:
  • 146 Answers
This is a convergence problem. The output ic needs to be replaced.
Posted on Apr 01, 2008
Have a Mitsubishi Big Screen, Model VS-5043 (AC 120V, 60H, 210W), and get no picture. I believe all I need are bulbs. Think it's worth a try to get them or should I have a repair guy get a look-see?
Hi dejjjavuu,
You have 50% chance that it is a bulb problem but you have a ballast board that supply the bulb also. The problem is, this board needs to check with an experienced technician for fault. But for me I've suspected also the bulb most especially if the unit is more than a year old, you can't test this bulb unless swap a new working bulb in the ballas board that's why you need to call an expert. However if you have a spare bulb you can swap it and try.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 09, 2011 | Mitsubishi VS-5043 50" Rear Projection...
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
I have a mitsubishi VS-5043....It shuts off after approximately a hour of watching, can it be repaired?
Yes, it can be repaired. There is so much heat inside the unit that is why it shuts off. When the heat gets high, then a component gets melted inside the unit.
The component that is most likely to get bad is a capacitor. Once a capacitor gets bad or melted, it begins to malfunction, like tripping off frequently, and other kinds of problem. Run a check on the power board and the main board for any bad capacitor and replace it with a new one.
Take care and good luck
Dec 20, 2010 | Mitsubishi VS-5043 50" Rear Projection...
Vs 5043 mitsubishi no picture
Dear dc_rock,
These the most common failures for this TV Model VS-5043- VZ3:
1. Check base bias Voltage of Q217, for 0 VDC (BIASED OFF) if .7 VDC (BIASED ON) check C268 (22 UFD 50 V) off C OF Q215 V-Protector on the SIGNAL PCB.
2. Vertical Beam Blanking Active, check PIN 4 of IC401 for 3 VDC. If missing check IC202 (5V REG) PART # 266P932010, on The SIGNAL PCB.
3. Check Pin 6 of IC200 for 9 VDC if low or missing check IC203 Part#
270P210010 on the SIGNAL PCB.
Thanks for using FIXYA, big IRISH.
Dec 25, 2009 | Mitsubishi Televison & Video
Mitsubishi 290p080020 big screen tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 30, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mits Big Screen TV model #VS-5043
you have to take off the front framework to out the screen back in and it should still work
Aug 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi big screen tv
The VS5043 shuts down for many reasons. The most common are power supply issues. Bad caps, open resistors, shorted regulators, and missing voltages will cause the set to shutdown.
In my notesI have a location of components known to cause your problem( R5A03,L5A00,D5A21,Q5A04,Q5A03,C5A19,L902,IC900.IC700) All the parts listed are available. As I stated above there are many reasons for shutdown such as a bad flyback transformer that may not be available anymore. However, this type of failure needs to be properly diagnosed by a qualified technician. Good luck!
Sep 23, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
