Question about Ovens
Jenn- Air Model W256W
My wife was going to have the oven self clean and decided not to. Now there is "F8" in red letters in the display area and when we try to cancel it the fan goes on.
Cab you please help us to get it back to normal.
Thank you!
Randy Thill
  • 1 more comment
  • randythill Apr 02, 2008
    I could not find a plug as the unit is built in but I did shut off the circuit at the circuit box and it seems to have done the trick.
    Thank you so much Skill Will!!!
  • Anonymous Apr 17, 2008
    I have a Jenn-Air Model W256W. I was going to self clean, changed my mind, and then went to bake. Now I have "F8" flashing in red letters, the fan comes on, and when it isn't running, the oven beeps. I can't begin a clean cycle either. I have turned the oven off at the circuit breaker, left it off all night, and it hasn't corrected the problem. Thanks for any help! Q F
  • Queen Frag Apr 17, 2008
    I have a Jenn-air Model W256W. I started Clean mode, changed my mind, went to Bake mode and "F8" in red began flashing on the screen and the oven began beeping. I pressed cancel, but the oven fan began to run and the door locked. Within a couple of minutes, the "F8" began flashing again and beeping began. I repeated cancel and the fan began, "F8" disappeared, and the fan ran. I turned off the oven/microwave at the circuit box, left it off overnight, but the fault has not cleared itself. Any suggestions would be helpful. Thank you! Queen Frag
I have a jenn-air model w256w double oven which I just installed, the upper oven will not turn on; the only function pad that works is the probe and the cancel button. The lower oven does work. Any ideas of what to do. The oven is new, never been used.
Thanks for your help
Lindy
Posted on Jan 04, 2010
  • 53 Answers
Hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Posted on Apr 02, 2008
I have a problem with my jenn-air oven model w256w. On the touch appear F8 alarm. What can I do?
Hello- The code described- F8 indicates a failure in the clock, or control that operates oven. There is no simple 'fix' to this problem. "Self- clean" is the usual cause of board failure. Find a good tech to check it out on site Get an estimate before repair, and remember- Avoid "self-destruct" feature in the future. --Please reply if this info helps- have more if needed.  Thanks- Ed
Mar 18, 2010 | Jenn-Air Ovens
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Jun 19, 2008 | Ovens
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Jan 16, 2008 | Jenn-Air JJW8527C Expressions Collection...
Ovens Logo
475 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
