Question about Dryers
Maytag Dryer I have a Maytag Model#LDE8200ACW. The dryer runs, but it will not heat and the knob will not move. Is there something I can look at that might fix the problem.
  • 109 Answers
Yes inside the front panel ther is a white plastic thermal fuse with two wires going to it, if the dryer overheats this fuse will open, disabling the heater, check for open with meter.
Posted on Apr 01, 2008
SOURCE:
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
The dryer knob won't move while the dryer is on, so it will run for hours and never turn off. What needs to be replaced?
http://forum.appliancepartspros.com/dryer-repair/53816-maytag-dryer-runs-continuously-timer-auto.html
Apr 30, 2011 | GE EED4600GWW Dryer
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
Dryer Tunrs on and runs with no heat and timer never moves
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer timer knob
This control could be the problem IF the blower wheel ain't stripped, the dryer is clean, and the duct work is free of air restrictions.It is located on the blower housing next to the fuse.ec8cbee.jpg
Mar 18, 2010 | Maytag PYE2300AY Electric Dryer
I have a maytag dryer and when you start it the timer doesn't move - it will run for hours unless you stop it. now when you pull the knob to start it doesn't respond
Sounds like the problem is in your timer contacts, in which case you would have to replace your timer. A no heat scenario on auto dry could also cause a dryer to run continuously.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Heating Element rattling
I would not run the dryer and check the wires to the element and make sure there are no burned wires. I would also replace the heating element. It should not be loose in any way
Jul 27, 2007 | Maytag MDE2600 Electric Dryer
Dryers Logo
144 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
