Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma ip1800 --- load paper problem
Unable to print despite reloading paper many times. Paper feed mechanism tries to load paper but stops after approx. 1/2 in, then load paper popup window appears.
  • grammao6 Jul 18, 2008
    My paper will only feed a corner in and that is at an angle; what should I do?
  • Anonymous Mar 23, 2014
    not feeding paper
Posted on Jan 10, 2009
Pojkjjj
Posted on Apr 03, 2008
SOURCE:
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1800 paper jam
Turn it upside down and shake vigorously. Also, is there a reset hole where a paper clip inserted can do a system reset?
Aug 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 will not feed paper...One side jams and when I take the paper out, the jammed corner of the paper is folded under.
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Jun 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How do you load the paper in cannon ip1800
If the paper is loaded correctly--that is, placed in the paper holder and the side guides are tight against the paper, then the printer may need cleaning or it is defective. Check that there is not too much paper in the tray.
Many time the little rubber rollers that grab the paper become glazed and will not pick the paper up. Also, the feed mechanism may have just worn out.
If this is an older printer, it might need to be replaced if you can't find a shop to clean it for you.
Feb 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer either eats up paper or won't print anything out
what you might try is to find some thing that has been laminated on both sides and manuall feed it in to the feed rollers and see if you are able to push out what ever is in the paper path making your paper go in crooked. brother tech
Jan 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer paper reloading
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Dec 18, 2008 | Canon Pixma MP450 All-In-One InkJet...
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
1,264 people viewed this question
Clive
Clive
old marine
old marine
Ekse
