Question about Anthology Solutions Yellow Machine P400 (250004001) 250 GB Hard Drive Array
Did you ever get this fixed?
I have the same problem with my yellow machine... any solution?
    Problem Solver:
  • 9 Answers
The reason the drive won't mount is because the RAID is corrupted. It may require manual intervention. You would have to log in through root on the box. How long did you wait before trying to mount a partition. Trying waiting 2-3 hours (if you see lots of disk activity they are going through a repair). If you see none then you have to go the manual intervention route as root and run the "md" commands to identify the root cause and repair the volume.
The unofficial support website is: http://www.yellowmachinesupport.com/
You would need to use the RAID tools on the linux os loaded on the unit in order to repair.
Good luck,
David
Posted on Aug 06, 2010
Yellow light instead of green on my machine what does this mean
PS3 yellow light typically is related to the CPU or GPU that has become unseated due to overheating. Your best option is to contact Sony send in the unit and they will fix it for a fee it was $150. This is often referred to as the "yellow light of death".
Jul 04, 2016 | Video Game Consoles & Games
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
How can i fix taskalfa3050 colour machine error code C7903
could be the yellow dv unit but those drive motors have weak pico fuses in them. may have to replace the yellow dv drive motor
Oct 19, 2015 | Kyocera Office Equipment & Supplies
The time goes up to 0:02 and stop, the calorie, distance and speed stay on zero.
RUN THE software calibration for easy diagnostic and fix it. However you must adjut the REED swtich, test for open, loose wires or connector see the diagram attached. If your system has batteries replace the old ones by new ones ALKALINES, clean the contacts batteries spring from dirty, bad contacts, oxide, corrosion. Tight the ribbon cables inside display, clean it, and tight the upper connector and lower connector (clean it too)
God bless you
Nov 27, 2013 | Bowflex TreadClimber TC5
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
Where to take my sewing machines to be repair
you can check the yellow pages of the phone book for a sewing machine shop or in the browser type in sewing machine shops in the area your in
Apr 27, 2012 | Brother Sewing Machines
I have a nespresso latissima machine,Got it for x-mas, and now there is constant yellow light on the water (the tank is full, and there is a blue light when it is time to fill it up...) What does it mean?
I just had this same problem with my brand new Latissima premium and I fixed it by adjusting the water hardness setting. The yellow water warning light being constantly on means the machine thinks the water is too hard and the machine needs descaling. In my case, the machine just needed to learn how hard my water actually is. In the manuals that came with the machine you should have been given a ph testing strip and there are instructions in the user guide about how to adjust the water hardness settings. As soon as I did that, the yellow hard warning light immediately went off. In my case the water setting needed to be adjusted to the 7-14 ph setting. I'm attaching pics of the water hardness setting instructions from the manual.dberlyne_3.jpgdberlyne_2.jpgdberlyne_1.jpgdberlyne_0.jpgdberlyne.jpg
Dec 28, 2009 | Nespresso C190 Espresso Machine
Cartridge not recognized
Yes. Unplug machine from power. Wait 5 minutes. open scanner and take all the carts out. close scanner. plug machine to power again. machine will do the start up cleaning. Machine demands carts. insert NEW carts and give the answer in case you are asked by machine.
Do only change the carts when machine stopps for EMPTY cart. As long as it shows Nearly Empty everything is alright.
The machine has a drop counter and counts the ink drops down to zero when the flag is raised within the (nearly) empty carts. In case you take them out at that moment and reinsert again the ink inside will splash and raise the flag again. Control logic will be in trouble....
Nov 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Yellow color
What you can try is the following procedure:
1# Install new carts and make sure that they are really well placed (the procedure will consume a lot of ink)
2# press menu then start mono (blue copy button) then 4 times arrow up (tel index). Machine will be in maintenance mode.
press 7 then 6 then 4: display will show init_all
press start mono
machine will refill the tubes and the printhead with fresh ink and do some cleaning.
When maintenance is shown again press 0 (zero) then 9 when you are OUTSIDE US/CAN. Machine will print a test print.
If you are from US/CAN you have to leave the maintanence mode by pressing 9 then 9. Press ink etc. to do the test print job.
Do only one cleaning cycle in case you see some of the yellow blocks.
In case you still have trouble with seeing any yellow, the yellow ink channel or the print head is rotten and cant be fixed anymore.
Nov 20, 2007 | Brother MFC-620CN All-In-One InkJet...
Anthology Solutions Yellow Machine  P400 (250004001) 250 GB Hard Drive Array Logo
116 people viewed this question
Top Anthology Solutions Computers & Internet Experts
David Payne
David Payne
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
