Question about Nintendo Wii Console
Controller my controller buttons work; however nothing (like the hand) shows up on the screen. i thought it must be the sensor bar but when i did what youu said with a camera all dots at the sides are there. can youu help anymore?
    Problem Solver:
  • 16 Answers
Hi. You could try to resync the control(s) in question:
First turn on Wii, open the SD cover in front, press and release the red sync button found there. Then press the red sync button on the controller behind the battery cover, the process is done when the leds on the controller stops blinking. Hope this will work
Posted on Oct 08, 2008
    Scholar:
  • 119 Answers
If it's a new Wii Remote, make sure you take off the clear plastic film on the front of the Wii Remote. A lot of people forget to do this and it makes the remote have a difficult time "seeing" the sensor bar.
Posted on Apr 05, 2008
Try wiping the sensor part on the wii mote. also don't have any interfering electronics
SOURCE:
No hand is showing upon the screen
Check to make sure the sensor bar is securely plugged in. My sensor bar quit working because the wire got damaged and I just went and bought a wireless one and rechargeable batteries. Mostly the sensor bar is only used for the menu and any games that have target shooting like billiards. You can bowl, play baseball, tennis, and golf without it on Wii Sports. I hardly ever use my sensor bar since discovering that it isn't used as much as I thought. We just turn it on load the game and shut it off and everything works perfectly on most games.
Sep 17, 2012 | Nintendo Wii Console
My problem is the cursor (hand) does not come up on the screen, I thought it might be the control bar, so bought new one, but it still doesnt work.
Try re-linking the controller to the system. There is a small button inside the battery compartment, and a small button within the tab that opens up for the SD slot. Press the one on the console first, and then the one on the controller.
Jul 09, 2012 | Nintendo Wii Console
My Wii is not working. It will come on but the remote will not sync with the console (the hand does not appear on the scree). We purchased a new remote but it still is not working. We pushed the red...
You will have to update the wii to play newer games. Your controller problem if it does show a led light on the remote then its synced. If its just not showing you a hand on the screen then its probably your sensor bar. If your controller will not sync and all four leds flash then I would push the button on the console and push the button the remote then just try hitting the a or b buttons. I've also had to slap the remote after hitting the sync buttons to get it to sync. The update thing is normal though.
Jan 10, 2011 | Nintendo Wii Console
The wii hand is not showing we tried unplugging and plugging back in it will appear very shaky then dissappear. put new batteries in remotes and still nothing
There are a few possible causes for this issue. I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Try another controller.
2. Disconnect the sensor bar and reconnect it.
3. Check the sensor bar settings for the wii console. This can be done by clicking on the wii logo at the bottom left of the screen. Then with in the console setting click on sensor bar. There will be 2 options. Above TV and below TV. Verify that the correct setting is chosen.
3. Try your controller on another wii console.
If the above steps do not resolve the issue contact Nintendo directly.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 27, 2010 | Nintendo Wii Console
My hand held controls are not working.
Try cleaning the sensor bar or moving it.
Jun 29, 2010 | Nintendo Wii Remote Controller
Hands wont show on screen/minus and plus only work.
That means that your controller is successfully transmitting button presses to the wii via wifi, but not its infrared beam. The problem is most likley your sensor bar (you could confirm this by trying a different wiimote).
Another way to get some info on this problem is to examine the tip of your wiimote through a digital camera (it allows you to see the ir light). If there's no light, then it's probably a bad wiimote and not the sensor.
Apr 01, 2010 | Nintendo Wii Remote Controller
Wii controller. Hand cursor not showing
Take your cell phone and switch on the camera as if you would take a picture, now aim it at the far right or far left of the sensor bar. You should see 4 led light up on either side. If you see them your sensor bar is ok so check your batteries.
Jan 29, 2010 | Nintendo Wii Console
Wii controller
It sounds like your sensor bar is faulty(the lone black bar) Make sure it is plugged in and at the appropriate place.Just move it in front of the tv and try again, adjust it if no help buy new one. It would also be good if you had another controller just to rule out the controller being faulty.
Mar 07, 2009 | Nintendo Wii Console
The pointer hand is not showing on the tv screen
it is probally your sensor bar try moving that or go to sensor bar settings and change settings there
Jan 24, 2009 | Nintendo Wii Console
Wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
May 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
114 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
