Question about Cherokee Jeep Grand - RBB AM/FM Stereo Radio w/Cassette Player and integrated CD Changer Controls
2002 jeep grand cherokee turn signals
The turn signals or flasher on my jeep will not operate. No indicators or lamps.
  • laz lan May 11, 2010
    have you checked your fuses?
    Problem Solver:
  • 17 Answers
Check your fuses.
Posted on Jul 07, 2009
Changed flasher relay in grand cherokee, had flashers before and turn signals worked occasionally, now nothing
test the combo switch,
get the schematic,
then with a voltemeter probe the input to combo and output.
if imput is good, and output is bad the switch is bad. has the schematic.
the FSM even walks you step by step to each test.
Nov 24, 2013 | 2002 Jeep Grand Cherokee Limited
How can I fix the back lights on my 2002 jeep grand cheroke Laredo.
I assume "back lights" refers to the rear lamps and that "light fixture" refers to the entire right rear lamp assembly. There is a combination flasher in the junction block that controls flashing of the turn signals and the hazard function. The multi-function switch (on steering column?)selects left and right turn signals and the hazard operation. If the left side tail/stop lamp and turn lamp are OK, compare the lamp installation on the left rear with the lamp installation on your new right rear lamp assembly. If all checks out, turn on the park lamps and check the BLK/YEL wire for 12 volts to the tail light filament of the combination lamp. Next, turn the ignition switch on but do not start. Set the turn signal switch (MFS) for a right turn. Check the BRN/RED wire for 12 volts to flash the separate turn lamp. Finally, have someone step on the foot brake and check the WHT/TAN wire for 12 volts to the stop light filament of the combination lamp. If any voltage is missing, the trouble may be in the combination switch, the multi-function switch, or due to a missing ground connection (BLK wire) to the right rear lamp assembly.
Sep 09, 2012 | Jeep 2002 Grand Cherokee LAREDO
Where is the turn signal flasher relay on the 2002 jeep grand cherokee
it is in the fuse box left side of the steering collum the middle relay two on each side
Jan 25, 2012 | 2002 Jeep Grand Cherokee
My signals and flasher quit working 2002, Jeep Grand Cherokee
in your vehicles owner manual, look up fuses, and flasher units or flasher relay. Fuses are normally located under the dash, but when both turn signals quit working it is usually the relay. The relay is located under the hood yours owners manual should show you the location.
Oct 27, 2009 | 2002 Jeep Grand Cherokee
Turn signals not working on 1998 Jeep Grand Cherokee
the problem is the turn signal flasher module.
Apr 02, 2009 | 1998 Jeep Grand Cherokee
2002 jeep grand cherokee v8 ltd signal won't turn off
most likely a broken turn signal switch assem.
- Rudy
Mar 28, 2009 | 2002 Jeep Grand Cherokee
Turn signal sometimes flashes both rear turning lights
I would check the flasher due to the fact that is where power is being sent to to send out intermit voltage to the rear lamps. check for open or groundin wires
Dec 10, 2008 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
168 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
