Help hi please help i brought this heater it worked beautifully for 2 days, i turned it on it started to warm up then it all went out including the clock now it looks dead im hopeing it has something simple like a fuse and it hasnt just blown up and its nearly new, thanx,hope to receive a reply
  • susen
    susen Apr 02, 2008
    it has a panel on the back that reads
    SouthCorp Product # 8217G
    Quasas Premier Electronic - Grey
    on the front it reads
    Quasar Elite
    G - Series
    thanx so much i really love the heater and hate to have to throw it out would actually hurt lol
    suz
  • Anonymous May 11, 2010
    Need to know just what brand of heater and model #
  • 3 Answers
Check if it is in automatic and if so try manual. Also check to see if there is a safety switch on the bottom that may be stuck. If not, you may have a defective switch that may be repaired/replaced
Posted on Apr 03, 2008
SOURCE:
2009 Ford Focus, temp gauge says running cool (gauge stick measures at about 1/4 to 1/3 on dashboard gauge all the time, but sometimes will take about 30-35 miles and using heater to warm up fully to 1/2...
i
1st ithink you got a bad tempture sensor 2nd you may have a stuck blend door third it may have a bad control ac control head
check your temperature cable too.
Oct 25, 2013 | 2000 Ford Focus
The refrigerator is not cooling for more than two days
After 2 days when it starts to warm up are you turning it off and then turning it on again later and it works? If it is working repetitively for 2 days at a time and you are having to turn it off in between then you most likely have a circulation problem. It will be either the circulation fan or the defrost element. These are both behind the rear panel. If it is working for 2 day intervals and your doing nothing inbetween then sure it may be the controls.
Jul 10, 2013 | Refrigerators
Heater is not working suzuki grand vitara
Just brought my GV in today and they replaced the fan for the heat.On my drive home all was warm but when i went out 2 hours later no fan again.wtf?
Jan 05, 2011 | 2006 Suzuki Grand Vitara
My pool guy had turned off the remote feature of the gas pool water heater. I have held the 3 buttons and now it says press clock ( clk) and the top right flashes service. How do I get back into remote...
The clock indicator means the firemans switch is open. If you are running the heater remotely and thru a time clock the time clock is still off. Turn all the equipment on including the timer and you should be able to put the heater into remote mode.
If you still have trouble, please comment with your actual model and serial number from inside the heater.
John
Nov 05, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Clock keeps working plus 1 hour Lexibook RP200GB set the time but every night it resets to 1 hour ahead can't find user manual please help
Hope this helps I had same irratating problem
1. The RP200 is designed to automatically synchronize its calendar clock once it is brought within a range of 1500km of the Frankfurt DCF77 radio signal. When the RP200 is brought within this range, its auto-control mechanism will override all manual settings.
2. The clock automatically starts scanning the RF 433MHz signal after new batteries are inserted in the main unit. When receiving the RF 433MHz radio signal, the Radio Tower symbol starts to blink. A complete reception generally takes about 10 minutes, depending on the strength of the radio signal.
3. When the reception is complete, the Radio Tower symbol will stop blinking and remain solid
4. For an optimal reception, place the clock away from metal objects and electrical appliances (i.e. television, computer, monitor, etc) to minimize interference.
Notes:
• The unit will receive the RCC signals every day at 2am.
• The RCC signal can also be triggered by holding the key for 2
seconds in time mode.
• When the unit is searching or receiving the RCC signal (which lasts
about 5 minutes), none of the keys is working except the key.
• Press and hold the key for 2 seconds if you wish to stop to the
RCC signal search.
If the RP200 is brought outside the range of the Frankfurt DCF77 radio signal or if the signal is interfered, please set the time and date manually according to the instructions below. If the unit is located within the radio-controlled range, you may want to customize some of the clock settings.
Note: When no key is pressed for more than one minute, the unit returns to time mode (time, date and temperature display
World Time Clock
This function allows you to adjust the clock to a time zone. It is
particularly useful for travelers. Set the clock to the city you are located in, or to a city in the same time zone.
1. In time mode, press [MODE] twice to select the world time clock.
2. Press the key to select the city in which you are located.
3. Press to adjust the summer saving time function.
4. Press and hold [SET] to set the world time as the local time. When the local time is the same as the world time, the icon flashes.
May 15, 2010 | Toys
Olds ciers 93 ... stalls, and mechanics can't solve help
I would look to see if you got a broken ground wire!!! witch are a big thing on todays computered cars. I know you have dumped a lot of money in your lawn ornament but one unhooked or dirty ground wire not making a connection can reak havick with everything, I would chk.for ground issues like around the fuel tank and where they hook to engine to body to frame or k-member.
Apr 14, 2009 | 1993 Oldsmobile Cutlass Ciera
It will not turn on.
give this s try
unplug it wait for 5 min. then plug back in
Feb 11, 2009 | Lakewood (5500) Oil Filled Radiator Heater
Power went off for about 2 seconds. when power came on, the clock was still running but touching each and every other button brought no result. cannot change the clock, or use the microwave at all.
the next day, i tried the microwave again and it worked fine. don't know what caused the problem other than the power outage - we have quite a few of them.
Jul 21, 2008 | Whirlpool Microwave Ovens
T600d
stop buying trutech garbage, you bozo
Mar 24, 2008 | TruTech TT320
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
