Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Door close message
When I turn my machine on, I receive a message to "Close section properly". The section is closed properly. What can I do?
    Scholar:
  • 141 Answers
Witch section are you talking about ????
Posted on Apr 02, 2008
Driver door doesn,t close
If you look at the latch mechanism on the door you will see a slotted piece that will line up with the latch receiver on the door post. When the door is open, this slot should be turned so that it can grab the receiver when you close the door. Try moving it into the proper position while manually pulling the door open handle.
Mar 06, 2015 | 2001 Audi TT
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
Message on screen saying 'close section properly'
You must be changed the broken parts or improvised something because the open door affected the vertical transport tray of the paper.
Apr 11, 2013 | Konica Minolta Office Equipment & Supplies
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error message dE
HELLO,
WHAT THIS SIMPLY MEANS IS THAT THE DOOR OF THE WASHER IS NOT PROPERLY CLOSE OR LOCK.
WHAT YOU ARE TO DO TO FIX UP THIS PROBLEM IS, FIRST OF ALL PUT OFF THE WASHER FROM POWER SUPPLY THEN PUT IT ON AGAIN AFTER SOME TIME, THEN OPEN THE DOOR OF THE WASHER AND CLOSE IT BACK AND / THEN MAKE SURE THAT THE DOOR IS PROPERLY CLOSE OR LOCK.
GOOD LOCK AND THANKS FOR USING FIXYA.
Nov 23, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung 600N transfer belt
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
Apr 20, 2008 | Samsung CLP-600N Laser Printer
Problems sending and receiving faxes
then there is a sensor problem, here is the manual check troubleshooting section
http://www.retrevo.com/s/brother+2820+fax++manual
Sep 07, 2007 | Brother IntelliFax-2820 Laser Fax
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
285 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
