Black vertical line 3inches in from the left on my fujitsu PDS4233W-H plasma screen
    President:
  • 1,779 Answers
If the line is all the way from top to bottom, it could be your upper and lower buffer boards or your plasma display unit is bad. I suggest you contact a servicer for your brand.
Posted on Apr 01, 2008
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
I need to swap motherboards from fujitsu t.v how can this be done?
If you remove the back of the tv you will see where the boards sit, you will have a power supply, Decoder/signal board plus other boards that convert the horizontal and vertical signal.
Mar 06, 2012 | Fujitsu PDS4233W Flat Panel Television
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
