Question about Bernina Virtuosa 160
Automatic buttonholer won't work
The machine sews first bead forward and stop at desired location and then stitches back butgets hung up at end and won't come forward again. So it is only doing half the buttonhole
  • 202 Answers
Your buttonhole foot needs to be recalibrated to your machine by a technician. Takes about 5 minutes or so.
Posted on Oct 27, 2008
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
Sews one spot won go forward back buttonhole
It is stuck on bar tack...change the mode to normal, reset then try again
Mar 12, 2014 | Kenmore Sewing Machines
How to make a button hole
I don't know that machine, but generally on older machines, you put a buttonhole foot on the machine, set one of the buttons in the back-end of the slot so that it adjusts the size needed automatically. Then you set the machine stitch setting on 1 and set the width to make a satin stitch (a close zig-zag) down one side of buttonhole. You sew until the buttonhole foot makes the button hit near the foot; it will stop you, basically. Then you change stitch dial to 2 to make the bottom of the buttonhole, then 3 to make the other side, then 4 to make the top side. Then you remove the fabric and cut open the buttonhole (I use FrayCheck fist) Try some buttonholes on scrap fabric first, you will figure it out by trial and error.
If your machine is newer, they automatically can sew a buttonhole, but each one does it differently, Sorry.
Dec 09, 2013 | Euro-Pro Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Sep 21, 2012 | Sewing Machines
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Bernina 240, won't complete the buttonhole
Double check the instructions and if there is still an issue, call the Bernina dealer and tell them what is wrong.
Ask if someone will be available to look at the machine when you come in .... you need one-on-one assistance.
Mar 07, 2010 | Bernina Sewing Machines
Sewing Machines Logo
326 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
