Sonic update manager not working...get message at startup that I cannot get rid of
    Sergeant:
  • 349 Answers
  • go to start/run
  • when box opens, type in “ msconfig
  • go to start up tab and de-select the item that corresponds to that message.
  • close off, and next time you boot it will be gone
good luck
Terry
Posted on Apr 02, 2008
SOURCE:
I have this window that keeps popping up ''sonic Update Manager''. They want me to put in a cd that has the file um.msi in it. This was a download so I do not have a disk. I continually ''end Task'' in the...
Follow this procedure and your problem will be resolved. Do exactly i say..!
Step 1:- First Downlaod the windows Clean up utility.
http://support.microsoft.com/kb/290301
Click on the link above --> and then Under Summary Option on this page.
Click on the link mention below:-
( Download the Windows Installer Cleanup Utility package now. )
Install the windows clean up utility on the computer.
Once it is installed Hit the finish button.
Now Click on start-->go to All programs-->navigate
Microsoft windows Clean up utility software.--> click on it and runn it.
Once the Clean up utility window opens up.
Find out sonic Update Manager in the list you see.
Click on it and highlight it .
Now click on the button remove at the botton of that screen.
Once it is gone. Restart the computer your system will not pop up that message again.
( Reason :- The reason why you are getting that message is that the sonic Update Manager software is not installed properly on your system which is why it keeps poping up the MSI ( microsoft Installer ) on your screen for sonic Update Manager. )
So to get rid of it just remove the MSI from the list in windows clean up utility and it will not pop up again.
Let me know if it works for you.
Please do follow the instructions as provided. It will work.
May 11, 2010 | Computers & Internet
It's a message keep popping up on the screen about sonic updated manage some like that
This is about Sonic software installed on your PC. If your PC is new then just update it. Please use this link: http://tools.roxio.com/support/dell/isum_hotfix.exe
If you're not using it and really wants to get rid of it, then all you have to do is to just disable it. To disable the Sonic Update service that starts up when you computer starts, you can go to Start, click on Run, and then type in MSCONFIG and pressing Enter .
Next click on the Startup tab and you’ll see a list of all of the processes that start up when your computer starts up. You can uncheck any service to prevent it from loading during bootup. For the Sonic software, you need to search for startup item named sgtray, or that has the words Sonic Update Manager or Update Manager in the path for the command or location. Also, if you see isuspm or issch, go ahead and uncheck them too.
Hope this help . . .
Nov 08, 2009 | Computers & Internet
either uninstall sonic or
uncheck the sonic software in MSconfig
MSconfig
goto Start-Run-type msconfig
click on Startup tab
unclick any reference to sonic software
reboot
Oct 09, 2009 | Computers & Internet
CAN'T INSTALL WINDOWS SERVICE PACK 3 (KB936929) and SONIC UPDATE MANAGER
All you need to do is open sonic update and disable sonic update manager from running automatically.Then reinstall the updates.
May 16, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
Problem = (windows service pack) + analogue power saving) + (sonic update) = dead pc for no apparent reason = reboots itself = grrrrr
Hi
Great so far you have excellent work in analyzing the problem now, to stop a paitcular update from being installed you have to
1.Go to Control Panel
2.Open Security Center
3. Click Automatic Updates
4. Choose the Option saying "Notify me but dont autoamtically download or install them"
By doing so the update manager will evrey time ask you which updates to download and install you simply have to click on the chekbox to accept or reject them. (But do read the instruction with the updates that, what will be the changes otherwise you may miss some imporatant update?)
This is what i have been doing over the years any till now I dont have problem with the update manager.
May 16, 2009 | Microsoft Windows XP Professional With...
A pop up.refuses to be deleated its called (sonic update manager) It has not been asked for & messes up logging in & logging out.
This pop up is because Sonic update Manager is running in the background. If you don't use Sonic then uninstall it else if you want to keep Sonic but get rid of this pop-up then
click on start --> Run --> type msconfig in the run box
Go to Services tab and first check the bottom check box that says "Hide all Microsoft services" then go through the list and see if you can find anything that matches the description of Sonic update Manager and uncheck it.
Click on the Startup tab and uncheck the items that match the sonic description.
Apply the changes and the computer would ask you to reboot to apply the changes, reboot the computer.
Let me know if you still face issues after that.
Please rate the solution
Regards,
Srinivas
Apr 08, 2009 | Computers & Internet
When I reboot my PC or open Sonic, I get a Sonic Update Manager window that says "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the 'Sonic...
Download and install CCleaner.
You can use ccleaner to clean up all windows and internet temporary files, ren a registry clean and also in "tools > startup" stop that annoying Sinic nag screen from coming up.
www.ccleaner.com
Aug 09, 2008 | Sonic Computers & Internet
Hi, I bought a Dell computer which had a faulty Sonic programme in it. I have completely deleted Sonic from my machine but Windows Installer is still trying to download Sonic every time I start up my pc. ...
go to start....run
In the box type msconfig
Go to the startups. Look for a program that relates to sonic update and uncheck the box. Press okay, restart the computer at the prompt. When it boots back up, click ok in the box that will appear. It should be taken care of.
Jul 03, 2008 | Sonic Computers & Internet
Getting message at start up that I have to configure sonic update manager...but do not have disk and can't get rid of message
  • go to start/run then type in "cmd
  • when box opens, type in msconfig
good luck
Terry
Apr 01, 2008 | Computers & Internet
Please wait while windows configures sonic update manager...the feature you are trying to use is on a CD-rom or other removable disk that is not available....etc. I cannot get rid of this start up message
good luck
Terry
Open Questions:
Computers & Internet Logo
125 people viewed this question
Ekse
Alun Cox
