Getting message at start up that I have to configure sonic update manager...but do not have disk and can't get rid of message
    Sergeant:
  • 349 Answers
  • go to start/run then type in "cmd
  • when box opens, type in msconfig
  • go to start up tab and de-select the item that corresponds to that message.
  • close off, and next time you boot it will be gone
good luck
Terry
Posted on Apr 02, 2008
SOURCE:
Can't get rid of the Sonic Activation Message that appears on Dell computers "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the 'Sonic Activation...
Sonic is typically a cd burner software. look for any CD utilities running down by the clock and right click on the icon to exit them. Maybe look for a sonic or CD/DVD software package that would have come on a disk with your computer , insert it and re-install the package, that may do it for you. If the nag is tooo annoying, for the interim look in your start menu under startup and delete anything in there that is in relation to sonic or cd writing software. Hope that helps you. Cheers
Aug 29, 2010 | Computers & Internet
I have this window that keeps popping up ''sonic Update Manager''. They want me to put in a cd that has the file um.msi in it. This was a download so I do not have a disk. I continually ''end Task'' in the...
Follow this procedure and your problem will be resolved. Do exactly i say..!
Step 1:- First Downlaod the windows Clean up utility.
http://support.microsoft.com/kb/290301
Click on the link above --> and then Under Summary Option on this page.
Click on the link mention below:-
( Download the Windows Installer Cleanup Utility package now. )
Install the windows clean up utility on the computer.
Once it is installed Hit the finish button.
Now Click on start-->go to All programs-->navigate
Microsoft windows Clean up utility software.--> click on it and runn it.
Once the Clean up utility window opens up.
Find out sonic Update Manager in the list you see.
Click on it and highlight it .
Now click on the button remove at the botton of that screen.
Once it is gone. Restart the computer your system will not pop up that message again.
( Reason :- The reason why you are getting that message is that the sonic Update Manager software is not installed properly on your system which is why it keeps poping up the MSI ( microsoft Installer ) on your screen for sonic Update Manager. )
So to get rid of it just remove the MSI from the list in windows clean up utility and it will not pop up again.
Let me know if it works for you.
Please do follow the instructions as provided. It will work.
May 11, 2010 | Computers & Internet
I have this window that keeps popping up ''Sonic Update Manager''. They want me to put in a CD that has the file UM.MSI in it. This was a download so I do not have a disk. I continually ''End Task'' in the...
There could or should be an item in setup that allow you to disable the auto update feature. Failing that, you could search the registry for the keys that invoke this, but that is for advanced users. Otherwise, download Revo Unistaller and get quit of the program.
Mar 19, 2010 | Dell Computers & Internet
It's a message keep popping up on the screen about sonic updated manage some like that
This is about Sonic software installed on your PC. If your PC is new then just update it. Please use this link: http://tools.roxio.com/support/dell/isum_hotfix.exe
If you're not using it and really wants to get rid of it, then all you have to do is to just disable it. To disable the Sonic Update service that starts up when you computer starts, you can go to Start, click on Run, and then type in MSCONFIG and pressing Enter .
Next click on the Startup tab and you’ll see a list of all of the processes that start up when your computer starts up. You can uncheck any service to prevent it from loading during bootup. For the Sonic software, you need to search for startup item named sgtray, or that has the words Sonic Update Manager or Update Manager in the path for the command or location. Also, if you see isuspm or issch, go ahead and uncheck them too.
Hope this help . . .
Nov 08, 2009 | Computers & Internet
Sonic update manager
either uninstall sonic or
uncheck the sonic software in MSconfig
MSconfig
goto Start-Run-type msconfig
click on Startup tab
unclick any reference to sonic software
reboot
Oct 09, 2009 | Computers & Internet
CAN'T INSTALL WINDOWS SERVICE PACK 3 (KB936929) and SONIC UPDATE MANAGER
All you need to do is open sonic update and disable sonic update manager from running automatically.Then reinstall the updates.
May 16, 2009 | Dell Precision 380 P4 Dual Core 3 GHz...
A pop up.refuses to be deleated its called (sonic update manager) It has not been asked for & messes up logging in & logging out.
This pop up is because Sonic update Manager is running in the background. If you don't use Sonic then uninstall it else if you want to keep Sonic but get rid of this pop-up then
click on start --> Run --> type msconfig in the run box
Go to Services tab and first check the bottom check box that says "Hide all Microsoft services" then go through the list and see if you can find anything that matches the description of Sonic update Manager and uncheck it.
Click on the Startup tab and uncheck the items that match the sonic description.
Apply the changes and the computer would ask you to reboot to apply the changes, reboot the computer.
Let me know if you still face issues after that.
Please rate the solution
Regards,
Srinivas
Apr 08, 2009 | Computers & Internet
When I reboot my PC or open Sonic, I get a Sonic Update Manager window that says "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the 'Sonic...
Download and install CCleaner.
You can use ccleaner to clean up all windows and internet temporary files, ren a registry clean and also in "tools > startup" stop that annoying Sinic nag screen from coming up.
www.ccleaner.com
Aug 09, 2008 | Sonic Computers & Internet
Sonic update manager not working...get message at startup that I cannot get rid of
  • go to start/run
  • when box opens, type in “ msconfig
good luck
Terry
Apr 01, 2008 | Computers & Internet
Please wait while windows configures sonic update manager...the feature you are trying to use is on a CD-rom or other removable disk that is not available....etc. I cannot get rid of this start up message
good luck
Terry
Open Questions:
\Q;- RICOH PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This RICOH PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 RICOH PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the RICOH PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, RICOH PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH PRINTER USA Calling RICOH PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH PRINTER USA's phone numbers against each other. Contacting RICOH PRINTER USA in General While [+I8OO-8O3-1O69] is RICOH PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach RICOH PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH PRINTER USA.
Oct 18, 2019 | Ricoh Computers & Internet
\Q;- KODAK PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This KODAK PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 KODAK PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the KODAK PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, KODAK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK PRINTER USA Calling KODAK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK PRINTER USA's phone numbers against each other. Contacting KODAK PRINTER USA in General While [+I8OO-8O3-1O69] is KODAK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK PRINTER USA.
Oct 18, 2019 | Kodak Computers & Internet
\Q;- TOSHIBA PRINTER customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This TOSHIBA PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 TOSHIBA PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the TOSHIBA PRINTER USA techanical support department for problems like Where to buy, Complaint, techanical support, Repairs, Returns. As far as we can tell, TOSHIBA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA PRINTER USA has 2 phone numbers and 4 different ways to get techanical help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA PRINTER USA with help from techanicals like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA PRINTER USA Calling TOSHIBA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA PRINTER USA techanical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA PRINTER USA's techanical support department, you may need to provide them with information that identifies you as a techanical, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA PRINTER USA's phone numbers against each other. Contacting TOSHIBA PRINTER USA in General While [+I8OO-8O3-1O69] is TOSHIBA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their techanical support team. You already know from reading above that[+ I8OO-8O3-1O69] is their best techanical phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA PRINTER USA help by calling them, is that other techanicals give their techanical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA PRINTER USA.
Oct 18, 2019 | Toshiba Computers & Internet
Computers & Internet Logo
32 people viewed this question
Ekse
Alun Cox
