Question about Nikon N55 35mm SLR Camera
Half battery life
The battery life is 50% even after replacing them and the camera won't work
  • nugget1972 Apr 26, 2008
    same problem too a picture and the camera just stop working. if itake the batteries out and put back in the camera come on for a second the blanks back out
    Scholar:
  • 85 Answers
Try with alkaline batteries
Posted on Apr 02, 2008
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Places like Batteries + are able to replace some tablet batteries.
Jan 20, 2015 | Amazon Kindle Fire HD
Battery life only half
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Feb 24, 2012 | Motorola Cell Phones
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
I have a HP Pavillion DV6 And I been expieriencing a problem where the compter shut down on me so I got a replacement battery and it came on and it was working for about a half hour and I hd it on the...
best to buy compatable or reccomended battery,,theres a lot of variation similar voltage/amp etc even ones that suggest peformance is better but only mess up your system.
Good luck
Davey Snake
Jul 20, 2011 | HP Computers & Internet
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
My Sony CybershotDSC-P200 camera works when it is plugged in, and the screen shows that it's charged. But as soon as I unplug it, it won't even turn on. Is there anything I can do to fix it? Would...
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
May 21, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Short battery life
its not the charger its time for a new battery
Dec 17, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Olympus FE310 Series, Battery Problem
Hi, I have had the same problem with the battery not working.  I have changed batteries several times, with no change.  I bought the camera when I was pregnant so I could have a camera in my bag to take spontaneous photos of my baby but was disappointed at the birth and ever since because the battery is not dependable! I took it into the shop and was informed there could be a $90 charge if there is no mechanical problems... :-((
Jul 31, 2008 | Olympus Camedia Stylus 300 Digital Camera
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Its dead with new batteries in it
hello,i have pentax optio 50 digital camera,my problem is it won't on.I have inserted the newly charged batteries but still doesn't work. I can not open it..it does not on..
Dec 12, 2007 | Pentax Optio 50 Digital Camera
Nikon N55 35mm SLR Camera Logo
32 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
