My TEAC A550RX stereo cassette deck will not play tapes. Power is on and the tape drive will not respond to commands when pushing the buttons on the face of the face of the unit. The unit has not been used for a few years and I recently wanted to put it back in service. What can be wrong and where can I get service? Russ
  • russ1011 Apr 02, 2008
    Good advice, now I need to find a service center that will work on this unit.
    Thanks
  • Anonymous Jul 05, 2008
    I have a similar problem with my Teac A 550RX. The buttons respond and relays click and clunk and the motor is running, but it won't play, fast forward or rewind. When I opened up the unit I saw that it had thrown the flat wide belt, to I put it back on, but the unit is still not operating. Could the belt have stretched to the point that it doesn't have enough tension anymore to turn the flywheel?
  • 4,234 Answers
If the unit ends up in the middle of a cycle, the front panel will appear to be unusable. With a unit that has been idle for a long time, the belts and motors may be a little sluggish. This unit needs a general overhaul and the belts replaced. This should not be a major expense. Figure about $10 in belts and your ocal labor charge for the repair. If I remember correctly, this unit uses both a flat and square belt.
Dan
Posted on Apr 01, 2008
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
When playing a tape it may stop randomly and the counter displays zero. I have to push play button again and it goes on; but may stop after a while. It does not depend on cassette type or tape length (I...
This would indicate a power supply problem in that the counter being reset. I would check the entire power supply for a any thermal broken solder joints and redo them with the power off. If you need further help I am in the Chicago area and am known as Skywave Tape Deck Repair.
Feb 07, 2011 | Teac V-8030 Dual Cassette Deck
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
508 people viewed this question
 Grubhead
Grubhead
