Looks like the print job wanted letter sized paper in the tray.
Tray 1 load ltr WHAT DOES THIS MEAN
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
the problem is from Word.
Change the settings: File-Page Setup-A4 (not letter).
IT'S WORKING!!!!
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Rosener
AFter we tried everything, the paper we bought was apparently not quality controlled and mixed with different weights of paper that caused the error. We purchased another brand and have had no problems so far...
SOURCE: error message Tray1 Load LTR
This meens a printjob was send to print on "letter" papersize, all though there is another papersize selected in tray 1.
Push the select button several times and the machine will print this job
