Question about Compaq Presario R3000 Notebook
Compaq Presario R3000 not booting up
My Compaq Presario R3000 laptop (bought June 2004) does not boot up. With the CD-ROM drive and hard drive in, it gives a faint repetitive ticking sound.
Originally, the laptop froze in the middle of an MS Word Application, and then did not boot up again since. The main power light comes on, but that's about it.
I have tried the following:
1. Removed Battery Pack and all electrical connection. Re-connected battery pack - still no change. I have now permanently removed the battery pack and try with the main power supply.
2. Also removed CD-ROM drive. The faint ticking sound stops (thereby assuming it was originally from the CD_ROM drive). There is another small repetitive sound coming from the hard drive. Still does not boot up.
3. Also removed hard drive. I was hoping to see an error message on the screen. I still don't see anything. I converted my hard drive to an external hard drive with an adapter and the data is safe on that.
4. Also removed RAM chip from under the keyboard and put it on the back of the computer in the second slot (I only have one 512 MB RAM chip). Still no change, and it doesn't boot up.
5. Also removed RAM chip completely from computer. I do not get a beeping sound when I switch on the laptop. I am not sure how to diagnose after this.
Hope you guys have seen something like this before and have some suggestions!
Thanks,
Venkat
  • 5 more comments
  • matix Apr 05, 2008
    Thanks, redrivera.
    Actually, I should have phrased my query differently - nothing shows up on my laptop screen when I switch on the laptop. So, I don't even get a chance to go into the BIOS screen since it doesn't come up. (in other words, I cannot use my CD either). At this point, I am wondering whether I should get my motherboard checked.
    Thanks,
    Venkat
  • matix Apr 07, 2008
    I did try that(removing hard drive and CD romdrive) - there is still nothing showing up on the screen. The computer just stays on, with the fan whirring, and nothing coming upon the screen. I gave it to a repair shop that replaced the RAM chip with a new one - still no effect. The feeling was that maybe the video chip is faulty (am not sure what that may mean). In any case, doesn't look very bright from hereon :)
    Thanks for trying!
    Venkat
    Thanks for the suggestion- I will look into it and see if I can figure something else out. I converted my hard drive to an external hard drive, so that shouldn't be a worry for me. I don't intend to connect it back.
    Thanks!
  • SHYKE Apr 17, 2008
    I have the same problem. In addition, my laptop kept saying it is low on HD space (I have a 20GB hard drive) but I ignored the warning and kept working.
    Because I moved, I lost the original system restoration CD. Do you have any clue where can a get a system restoration CD for this particular laptop?
    Thank you in advance for any suggestion that would help restore my laptop to previous workable state.
  • oxrive66 Apr 05, 2009
    My Compaq Presario R3000 laptop does not boot up. Nothing shows up on my laptop screen when I switch ON the laptop. The CD-ROM drive makes a faint repetitive ticking sound.
  • Anonymous Mar 27, 2014
    It was so long ago, that I'm not sure what I removed.
    I'm not sure what program I removed.
    Novelist:
  • 236 Answers
Set the bios/cmos to boot first of your CD drive. get your support discs and restore to original. your hard drive OS has failed and needs to be re-installed. the problem maybe is that when you do that option you will get all your data erased. your solution to that since you can still get the data on the drive when used as external is to back it up. then full restore your system.
if you dont have your restore kit, you can use your Windows OS to fix it, repair option when you boot from CD.
Posted on Apr 02, 2008
  • Anonymous Apr 06, 2008
    remoive then your hardisk first and maybe the CD DVD drive first and then try to start your system ans just see first if there will be POST screen messages. let me know afterwartds
  • Anonymous Apr 07, 2008
    that guy who checked it and said could be the video chip..if that is the case then only the manufacturer can help you with that. But have it further checked. dont give up, it could even be your processor. in that case you made find a replacement for that so you dont loose the whole unit. from this time onwards do not connect your hdisk so as to avoid dmage to your hdisk turning on and off. until you get the system to work only then you reconnect your hdisk. it could also be a deffective power supply module. that's why i suggest have the manufacturer check. video display does not brekadown suddenly.
    New Friend:
If you go to Compaq's website... they have an extensive section on troubleshooting this exact problem. I have the same laptop, and it started doing the exact same thing described above by 'matix' .... I went thru the troubleshooting and found that one of my memory modules had failed.... I replaced the module, and my laptop is running just fine now....
Posted on Dec 29, 2009
I want sound so iwant sound device or driver sofatware imediatley so please help me sir
Posted on May 05, 2008
Try this it will really help to speed up your PC
Posted on Apr 05, 2008
SOURCE:
PXE-E61
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
May 26, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Compaq Presario R3000 compatible bios?
I Think the latest bios update for R3000 is F.35. Sounds like you need to reinstall OS or buy a new HD
Nov 27, 2008 | Compaq Presario R3000 Notebook
Won't boot
The error means that the computer is not seeing the hard drive.Hit F10 to get into BIOS and check that your hard drive is showing . If it is hit ESC and tell it to save settings. Then restart the PC.
If your hard drive does not show in BIOS, there is something wrong with it. It may be co-incidental that canceling the scan caused your hard drive to fail.
You can try to do an XP repair. Boot your XP cd:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Compaq Presario R3000 Notebook
I cant boot from the CD/DVD drive.
Watch on the bottom of the screen when the PC is re-booting for a "Boot from CD" message, it may go by quickly, and hit any key to boot from the CD.
Unleash Your Computers True Potential!
Apr 19, 2008 | Compaq Presario R3000 Notebook
ZV5000 laptop wont boot up
Hi, You will need to boot from a boot disc or your Windows operating CD and from there you will be able to format the hard drive and reload windows.
If your hard disc has corrupted then placing the windows cd in the drive it should boot directly from there as there is no other operating system available.
Let us know how you go,
SeaJade
Jan 25, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Boot screen of death??
IT seems to me that If you were to push the delete key or F2 and go into the bios and go into bootup devices and make sure that the first device is cdrom or your Hdd if thats all ok, try to take out your cd rom drive and replace it make sure it is pushed snuggley into place and retry it see if that works,You may also try the F8 keys and start from last known good configuration or safe mode, try that and let me know if it helps you out, thanks Happy Holiday bear001
Dec 16, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
1,145 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
