Question about Linksys PrintServer for USB with 4 port Switch: PSUS4 (NTSVLS0PSUS4) Print Server
Linksys not printing
My linksys PSUS4 was working perfectly now it won't work at all
  • karen602 Feb 10, 2009
    Our print server stopped working last night. When we go to the IP address for the server, it shows that the printer is offline. How do we get the status changed to online so we can print again?
As it is very old print server
u need to update its firmware ( software )
contact 1800-546-7114 for same ( linksys tech. support )
Posted on May 11, 2008
  • Anonymous May 11, 2008
    as it is very old print server
SOURCE:
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
Try removing printhead and soak it in a window cleaninig solution for a few hours or overnight. We made instructions on how to remove printhead in the video below:
Dec 31, 2012 | HP Photosmart C6100 All-In-One Printer
Schematics for seting up a printer
Configure and wire your systems as shown in the attached power point presentation.moz-screenshot.png 5f10200.tif
Jun 02, 2010 | Linksys (PSUS4) Print Server
HP Photosmart C3150 compatability with print server
I have a same print server but it works with my Epson printer. Well most print server manufacturers claim that their device should work but in reality they are still subjected to hardware compatibilities some printers will not work, I suggest you just try the same manufacturer as your printer, it may be a bit expensive than universal print servers but atleast your guaranteed that they will work and if it doesn't you have one company to deal with instead of you getting a run around by both companies on who'se fault is it why and why it's not working as they claim.
Anyways here's a link for HP's "wired" printservers.
HP Printservers
Nov 06, 2008 | HP Photosmart C3150 Printer
My printservers setup wizard utilities will not install model number psus4
This link will take you to the linksys website.
http://www.linksys.com/servlet/Satellite?childpagename=US%2FLayout&packedargs=c%3DL_Product_C2%26cid%3D1115416837650&pagename=Linksys%2FCommon%2FVisitorWrapper
Down load the driver and read the user guide and quick install guide.
Your computer needs the driver in order to recognize the device
Aug 01, 2008 | Office Equipment & Supplies
Computer not recognizing print server
If you connect your printer directly to your computer, were you able to print? Make sure that there is no firewall enabled in your computer (Double check windows firewall or any personal firewall, that could have been enabled).
Jul 12, 2008 | Linksys PrintServer for USB with 4 port...
PSUS4 problem "talking" to Canon S330
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
Nov 27, 2007 | Linksys PrintServer for USB with 4 port...
Linksys Psus4 printserver for usb with 4 port which i'm using to connect my hp1020 printer on the network ???
Hi please go through this link
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&rule=43040&docname=c00384459
Nov 16, 2007 | Linksys USB200M USB 2.0 Network Adapter
Network printing
I am afraid, PSUS4 is an older model of print server , which supports only ordinary printers. All in ones are not supported by PSUS4. Linksys have other print server which works with all in one printers. The model number is WPSM54G. Probably you can try that. Also, if the PSUS4 is less than one month old, you can get it replaced with the WPSM54G from the stores itself . The WPSM54G can be used as wired as well as wireless to the router. If you want to use the PSUS4, you may need an ordinary printer like Office jet or laser jet with USB 1.1 version.- Thank you
Oct 26, 2007 | Linksys (PSUS4) Print Server
Linksys print server psus4 held
Check the "sleep" time...is it around 2 hours? Also, check the sleep time on the printer too.
Aug 24, 2007 | Linksys (PSUS4) Print Server
610N dissapeared no lights, empty EIO, reset no help
If you're seeing it intermittently, try the following:
-remove it completely
-power cycle the printer with it out
-check your contacts (be sure no bent pins, etc)
-Try it in a different slot if you have one (most HP's with an internal jetdirect have 2-3 EIO slots, but since you don't mention what model printer you have I don't know for sure).
If it's not talking after all that, likely the jetdirect is actually dead. It's been known to happen. I wouldn't waste the money on a replacement, you'll have better luck getting an external card and it'll be cheaper, too.
HP sells both the JetDirect 170X and 175X externals; there's also the Linksys PSUS4, D-Link DP-300U, TrendNet TE100-P1P, or Netgear PS101NA. Price will vary between $45-80.
Mar 27, 2007 | HP JetDirect 610N Print Server
Computers & Internet Logo
250 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
