Question about Toshiba Satellite A75-S211 Notebook
CD/DVD drive isn't recognized / cannot load driver
Hi, I have a Toshiba Satellite A75-S211, and my computer doesn't recognize the CD/DVD rom drive. I went into the device manager, and tried to reinstall the driver, but doesn't seem to work. Under device manager it says that Windows cannot load the device driver, and I get a (Code 39) error. I went to the Toshiba website and downloaded "qe15advdramx", but that didn't seem to work either. I also tried Windows update, but haven't had any luck with that either. Any help will be very much appreciated. Thanks in advance.
  • rubenmr2 Apr 02, 2008
    I haven't upgraded my OS, my Operating system is Windows XP. It was originally working, but it just suddenly stopped working one day
    President:
  • 1,257 Answers
  • 43 Answers
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Posted on Sep 18, 2008
    Novelist:
  • 236 Answers
What is your operating system? have you upgraded yo a higher version? if you did then you must have installed a driver thatis not designed to work withy our OS now.
Posted on Apr 02, 2008
  • Anonymous Apr 02, 2008
    Ok.. now i seem to get an idea of what you are saying. Your PC wont recognize you CD/DVD right? You know Win XP itself will load standard drivers for your drive, you dont even have to download and install. what i see here is a hardware failure. if it was working before and now you have that kind of problem. Can you try to use the drive with another set and see if it will work? or can you find another CD/DVD drive that you can try in your unit. i dont think though that it is your main board because it can detect your hardisk and it boots normal. you will have this kind or trouble if your IDE controller is defective. but as i said your hardisk boots so the controller is fine, i think it is just the DVD drive. can you see if you can try replacing, just to test only.
    i forgot, check the connection of your DVD/CD drive it may be loose too, it is a slot/slide type so see maybe you can pull in and out for few times then try again to boot the system
SOURCE:
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
I have a Toshiba Satellite laptop with a SD-R2512 DVD drive that the unit will not recognize. It sees it in device manager and says that the drive is missing...code 39. I tried to delete it in that...
Seems like the DVD drive went bad.
My advice is try another DVD drive and install it on the same laptop. just to make sure the laptop is ok.
Please don;t forget to rate is this answer helps you in some way
Jun 25, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba satellite P105-S6104 DVD Rom wont open
    If brand new return for replacement! It is fubar - supposed to be recognized by CMOS and your OS.
    Sep 09, 2017 | Toshiba Satellite P105-S6104 Notebook
    Toshiba A105-S2051 Pioneer DVD-RAM DVR-K17 wont read discs
    you just remove cdrom drive from your device manager and restart your nonebook
    it will reinstall cd drive automatically
    Mar 26, 2008 | Toshiba Satellite A105 Notebook
    Toshiba Satellite A75-S206 DVD\CD-RW drive problem
    Hello GeneMat,
    I am Romeet,i will try and help you with this problem.Seems it could be an issue with the Combo DVD Drive's Driver Software or Firmware.
    Try This:
    From your Desktop:
    Right Click " My Computer" Icon and select "Properties"
    Go to "Hardware" Tab and select "Device Manager"
    Under Device Manager, scroll down to the "DVD/CDROM Drives" menu and click on the plus ( + ) Sign next to it
    Right Click the Drive name eg " Toshiba DVD-R TSST 2313" and select " Uninstall" Click yes to any prompts and restart your Laptop.
    After rebooting, Windows XP should pick up the drivers again, so wait a while for it to complete and until it notifies you that " Windows successfully completed installing your new hardware" or something to that effect and then try using the software cds again
    Best of luck!
    Regds
    Romeet
    Dec 01, 2007 | Toshiba Satellite A75-S206 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    336 people viewed this question
    Top Toshiba Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
