My Onkyo HT-R550 dose not turn on. - Audio Players & Recorders
  • 4,102 Answers
Hi have you checked that all the wires are in the right connectors and their is no short between the wires as this will cause the unit to shut down as it has a protection circuit that stops the unit from further damage.
Also have you checked any fuses
Posted on Apr 01, 2008
    Genius:
  • 3,422 Answers
HI,
You will need a technician to fix this bcecause the power supply is the problem area. set has gone into protection mode.
It may not be the board, however. It could be something as simple as the rectifier bridge shorted down or a couple of bad/gassy electrolytic caps (that may or may not be mounted on the board).
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO: Make sure you have power in the outlet by plugging a lamp into the same exact outlet.
THREE: Do a hard reset; merely unplug the line cord but leave it unplugged for 4 hours before powering up again.
FOUR: If still now power, listen for the clicking of a relay inside the set. If you hear the clicking sound you might hear two clicks; once when the power is first turned on and the second a fraction of a second afterwards. This is the protection circuit switching the set OFF to protect it from further damage. The protection circuit activates whenever there is a internal short in the set.
The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If this does not solve your problem then the problem then as i told you in the begining you will need a technician to fix this.
Goodluck,
Please don't forget to rate the solution.
SOURCE:
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
I want to use my turntable with my Onkyo HT-R550 receiver. What type of preamp should I get and where should I attach it in the back? Any suggestions are welcome! :)
HI U should have enough power in the onkyo to run the turntable...u can plug it into the rca socket marked in if u have rca plugs on you're player the in rca sockets r in between the out rca sockets & the front rca sockets ....if you're player has the old style plug u can plug it in just above the rca in socket.if u have no luck with them try the CD & tape input section under you're component video section good luck
Aug 11, 2015 | Onkyo Audio Players & Recorders
I have an Onkyo HT R550 hooked up to my blue ray via an optical audio cable,the question is why wont it do 7.1 at all it is a full onkyo 7.1 system
The limitation could be in either end. The player may not be set up to transmit the full 7.1 bitstream or the Onkyo may not be set up to play it (7.1 speakers defined, digital input assigned, calibration completed etc.)
You'll find all that in the manuals.
Aug 04, 2010 | Audio Players & Recorders
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
I can't get any audio from my PS3 through the HT-R550 I am trying to set up in my home. I have an HDMI cable connected/running from my PS3 into the reciever. I also have an HDMI running from my Plasma TV...
run everything to receiver each channel should work on own for audio
video to tv audio to input rca jacks
if have to much rca's for little bit of reciever input output rca's go out to walmart and buy a rca switch for sound
one side would be A the other side would be B
May 13, 2008 | Audio Players & Recorders
Onkyo HT R550 sound going in and out
Sh$T I had the same problem with an older model... went out and bought a new Onkyo... HT-R550 I have had it for 2 years as of January 2010
Dec 06, 2007 | Audio Players & Recorders
Onkyo HT-R520
Hello the HT-R520 is the model of the receiver that is part of the HT-S770 package. I suggest that you check the speaker settings. Check the level of the center speaker. If you need assistance please contact Onkyo at 800-229-1687 option #3. Thank you, Onkyo USA
Jul 02, 2017 | Onkyo HT-SR700 System
202 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
