Question about Refrigerators
I have a KitchenAid Supera Side by Side refrigerator (manf. 10/00)(Model KSRB25FHSS04)the water dispenser leaks and also water is leaking from the ice maker compartment into the tray. The leak on the water dispenser fills a glass of water every 20 mins. What needs to be done to correct this problem.
  • 26 Answers
First, check out your water supply. Make sure that if its a quick tap valve to your pipe, that it is at the 3, 9 or 12 oclock position if attached to horizontial pipe. If its mounted on the botton and its a self peirce valve, it may be restrcted with gunk build up. If the valve is ok on the pipe, you should replace the fill valve. Its not hard and you maybe able to save a few hundred dollars. It reall seems that it may be restricted because both areas of the feed are leaking.
Posted on Apr 01, 2008
My side by side refrigerators water dispenser tube drips into the tray?
I suspect the water valve is not shutting off complete enough and is leaking by out the dispenser. You will likely need to replace the water inlet valve, accessed from the back of the refrigerator.
Jun 19, 2014 | KitchenAid KSRS25IL Side by Side...
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
My refrigerator water dispenser leaks water in the water pan. The unit is about 10 year old. It just started leaking.How do I stop it from leaking?
If your water filter is located behind the grille at the bottom of the refrigerator the O ring seal is leaking. Happened to me. Get a new one.
Feb 21, 2014 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Leak in the water dispenser
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jun 30, 2009 | KitchenAid Superba KSRG25FK Side by Side...
My refigerator is not getting cold the fan is working normal
Probably the coolant has leaked out. Buy a second hand one..
Nov 25, 2008 | KitchenAid KSRS25IL Side by Side...
Water leaking from ice/water dispenser
hi there,
you may have a kink in the water line leading to the icemaker. the leak is due to warm water entering the icemaker itself. i would also check the water valve in the icemaker itself and ice actuators or paddles to any breakage.
Sep 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid Refrigerator Superba
heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Apr 07, 2008 | Refrigerators
The Water dispenser is leaking water
It's either a bad water valve or the switch in the dispenser is stuck.
Oct 19, 2007 | KitchenAid KSRG22FK Side by Side...
Refrigerators Logo
224 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
