Question about Kenmore Oasis HE 27062 Top Load Washer
Leaves soap residue
Regardless of the setting (heavy duty, normal,etc.) and by cutting way back on the amount of Tide HE detergent (1/8th of a cup) and regardless of the size of the load, reside is left on clothing (most obvious on dark items); the washer is 1 year, 2 months old; repairman suggested running a bottle of Sears brand Washer Magic, using the heavy load setting, and putting the soap directly in the bottom of the tub -- none of the above had any effect at all on the problem
    President:
  • Kenmore Master
  • 2,651 Answers
Theres a new product just hit hte market www.affresh.com try this stuff speciffically designed for the frontloaders and endorsed by whirlpool, makers of your machine
Posted on Apr 02, 2008
My wash water smells bad. I leave the lid open between loads. When I do a wash it smells really bad.
After extended use, your washing machine can develop odors from the water, soap, residue, etc. The easiest and first thing to try is washing machine cleaner. You add this to the washer and then run a wash cycle. The product comes with instructions. Depending on the condition of your washer, you may have to run the cleaner through more than once.
You can usually purchase a washing machine cleaning product form stores that carry laundry detergent.
Here is a link to a product that you can try::
http://tide.com/en-us/shop/special-needs/additives/tide-washing-machine-cleaner
Here is a link for cleaning of a washing machine:
http://www.goodhousekeeping.com/institute/a23727/how-to-clean-a-washing-machine/
Aug 29, 2015 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Washer is giving musty odor
Leave door open between uses. The odor is a build up of soap and softener. Use a cleaner like Affresh to clean out the build up. Then, start using HE detergent and cut back the amount of detergent you use. My clothes dont get dirty per se...I only use 1/4 of the cup. The only time you should be using a full cup is if you are dealing with farmers clothes, mechanics greasy clothes, football/soccer uniforms, etc. Start with a 1/4 cup and increase/decrease from there.
Feb 03, 2013 | Kenmore Washing Machines
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
Jun 12, 2012 | LG Washing Machines
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
What causes a bad smell to come from a washing machine
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
This is a very,very frustrating mistake that gives owners much grief.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Dec 12, 2010 | Washing Machines
My LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
1) Musty Odor
front door gasket
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Jun 30, 2010 | LG Washing Machines
Soapy smell in clothes
You might need to wash your washing machine.
Most consumers think they are doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
This was a very big *faux pas* on LG's part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective if used the proper way:
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Got that? LOL
Jun 13, 2010 | LG WM2487H Front Load Washer
Screen flashing "LE" and will not finish spin cycle?
1) Musty Odor
front door gasket
May 24, 2010 | LG WM-2277HW Front Load Washer
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
116 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
