Question about Microwave Ovens
I have a sharp carousel microwave model # R-1470A. I believe it may have blown a fuse, as nothing works. I did not recieve a book with the oven. I have the control panel pulled off. Do you have a manual on line that I can refer to? If I know what the fuse looks like, I can replace it myself, I hope.
  • Microwave Ovens Master
  • 9,098 Answers
On this model, the fuse is located between the door switches.
But a microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
Before you look into it further, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa:
We have the exploded view and wiring diagram at our site. They will help you locate and test the parts.
Feel free to reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 01, 2008
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Sharp R-1490 microwave 2000
the fuse to the magnetron may be blown or the mag it's self is gone. if the door switch was bad the unit wouldn't rotate the carousel. if it is the fuse (check with a multi-meter and check continuity across both side of the fuse, acheap one will do) if it is good, time to replace the micro, as they are cheap and repair would cost more than to replace. hope this helps.
Mar 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Blown Microwave
Most likely a shorted capacitor and a blown fuse. Very common problem on that model.
Jul 16, 2008 | Microwave Ovens
Microwave Ovens Logo
846 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
