Question about Samsung SyncMaster 713BM 17" LCD Monitor
Samsung syncmaster 713bm hoe can i reset it to factory settings?
Can tel me how to restore it to factory settings please thanks for your time
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
I have the same monitor with same probelm. I dont know if this is problem with samsungs specific model but the only way to work is the follow.
1. connect your pc to another monitor and set the resolution to 1024x768.
2. set the herz to 60mhz.
3. save the settings .
4. connect your samsung monitor with your pc
You must get clear picture. I dont know why it works 1024x768 with 60hz and not at higher resolutions but this is the only way to work the samsung syncmaster 713bm
Posted on Mar 15, 2013
  • matsak spiros
    matsak spiros Mar 15, 2013
  • 85 Answers
Im not so sure but i downloaded the pdf and it should be in the menu open from the monitor
http://downloadcenter.samsung.com/content/UM/200506/20050602113228171_BN59-00420Y-02Eng.pdf
Posted on Apr 01, 2008
SOURCE:
I have a Samsung SyncMaster 940BW. My young son played with the menu bottons and I cannot restore the screen to its original settings. How do I restore to factory settings?
catchymob, If, with monitor OFF, push and hold "menu" button, and then push the "on/off" button. Still not reset? Try visit to Samsung web site. Hope this helps. 12fixlouie
Let me know with reply or comment from you.
Aug 13, 2010 | Samsung Syncmaster 940BW LCD Monitor
Why my display show plug and play monitor instead SyncMaster 732nw?
U NEEDS TO INSTALL MONITOR CD COMES ALONG WITH MONITOR. THEN IT SHOWS SYNC MASTER. AND THE COLOR SETTINGS WILL BE ALIGNED AUTOMATICALLY.
Apr 17, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Facebook display problem Samsung SynchMaster 713BM monitor
it must be the drivers your using for the monitor. Have you checked the pins connector are all straight. as bent pins will cause this.
http://www.howtodrivers.com/model502115.html
webpage link for drivers
AndystUK
Vote me happy
Aug 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor problem...
if you go into the settings , there should be restore factory settings there if not , on nokias you can search for applications and items
Aug 29, 2009 | Nokia 6300 Cellular Phone
Very low sound
hi first format ur operating system. and install sound driver properly. u can also check ur headphone. if any problem headphone change it.
Jul 21, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
Apr 06, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Language
Please see the link below and here you can find all the procedure to change the language.
http://www.samsung.com/us/support/download/supportDownDetail.do?group=&type=&subtype=&model_nm=713BM&language=&cate_type=all&mType=UM&dType=D&vType=L&cttID=198137&prd_ia_cd=&disp_nm=713BM
Hope this will help you to resolve the issue.
Thanks
Oct 23, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Hi im wondering if you could help me i have a samsung syncmaster 713bm and it wont work with my pc because the person who i bouth it off was running it thro dvi monitor to pc lead and i want to run it thro...
no need for you to restore the monitor factory settings all you need is a converter from dvi to rgb connector, it is included in the set if not purchase one.
Apr 01, 2008 | Computers & Internet
Monitor will not respond
check for a bent pin on the cable.  There is no signal being picked up.
Oct 15, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung SyncMaster 713BM 17" LCD Monitor Logo
2,299 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
